Results 1 to 20 of 27
    Member mvvette97's Avatar
    leon iowa
    1997 corvette 00 WS6 TA
    most of my valve springs are broken
    Just done the cam swap about 150 miles ago. I was putting headers on tonight and while I had the valve covers off I thought the springs looked strange. Almost all of the springs on the very top coil that sits against the retainer is broken. Why would it of done that? The cam is the Comp 228/230 571/573 112lsa. The springs are comp 918. I also have the 7.425 pushrods. Is there a right and wrong way to set the spring down on the seat? I don't know what to do.
    San Diego
    Were the springs and retainers changed at the same time as the camshaft?
    leon iowa
    Quote Originally Posted by RRE101 View Post
    yep, i changed everything, springs retainers and pushrods. Does the blue stripe have to be lined up on the springs?
    Member Phlash_riot's Avatar
    Aug 2006
    San Diego
    Midnight Blue
    1999 T/A
    I don't know if these helps out or not but I read somewhere that when you get high performace springs you have the let the engine heat up(including the heads) before you go WOT. otherwise you could break the springs. I guess the hardend metal want to warm up to make it a bit more flexible...
    Have any pics of what you are looking at there?
    leon iowa
    Aug 2006
    San Diego
    Midnight Blue
    1999 T/A
    Wow.... ummm
    Did you break them in before going WOT(I will be honest i am not sure if performance spings need a "break in" but somewhere inside my head somethign is say to me that i read that you do.... Obviously I am not talking the type of break in that you have shown here)
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    springs made with todays processes and metals don't need a heat cycle. back in the olden days, engine builders would take the springs and put them in an oven to heat cycle them before installing them. i have read about some comp springs breaking the tips off of them a couple years ago.
    RI
    Mag Red
    2002 Vette
    I have been following his dilema on a couple of boards, he bought the springs from an Ebay vendor. Based on his description of installation problems and the coloring of the blue stripes and the metal, I am very suspicious these are Comp 918 knock-off's. 150 miles should be nothing for a true set of Comp 918's.
    leon iowa
    Quote Originally Posted by vettenuts View Post
    I think I have seen this user name before .You must be like me, on every forum I drove the car home just a bit ago. I think the highest rpm i had it was 2200. I'm scared to to even get on it. Do you know how much distance it should have between the top coils while compressed? I am going to pull the valve covers in a couple days just to check everything. I thought while I was in there I would measure the distance between the coils when compressed. If they are not broken and have the correct distance in the coils i will leave them but if not I'm going to check in to some duals.
    Impounded YoMommasTA's Avatar
    ne pa
    ebay the modern way to rip people off!
    Aug 2006
    San Diego
    Midnight Blue
    1999 T/A
    Some things are better to buy from the store or reputable online source.
    RI
    Mag Red
    2002 Vette
    Quote Originally Posted by mvvette97 View Post
    Beehive springs compress at the larger coils first, then the upper smaller coils. Here is an article written by David Vizard on the beehive design.
    David Vizard's Article On Beehive Springs
    leon iowa
    good article. If that is true then I should have no problem with running 571/573 lift. I drove it 120 miles lastnight and pulled the valve covers and so far so good. I haven't turned it loose yet though. I'm kinda scared to.
    Aug 2006
    San Diego
    Midnight Blue
    1999 T/A
    So you got your springs replaced? Let me know how it goes.. I am about to buy a set of the 918s. Did you get he titanium retainers as well?
    leon iowa
    I bought a new set. Comp is supposed to give me a refund but i haven't heard anything yet. When I first installed them I used the comp steel retainers. Now I am just using the stock retainers since the comp retainers fit so tight in the spring. The 918 is designed as a direct replacement so comp told me that the stock retainers would work just fine. So far I don't have any broken.
    RI
    Mag Red
    2002 Vette
    This is good news, hopefully you are all set. The retainers, and their extremely tight fit, are the likely cause. Not sure if I posted the link to David Vizard's article in Popular Hotrodding, but I know in his valve train book he discusses the bad affects of tight retainers and that the spring will fail up top, just like yours.
    Artic White
    99 SS
    Not sure how you drive your car but I know you need to get the engine up to regular operating temps before you can beat on the stronger springs (and the engine). When they are cold they are more "brittle" and easier to break. Best of luck to ya
    leon iowa
    yea I read that link. That was interetsing. I have been driving it everyday to work so maybe it will be ok
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Any spring needs to be installed and checked for coil bind!!!
    If you broke all the springs or most of them you had to be going into coil bind!!!!!
    And for those tiny single springs.......It's not going to make one bit of difference if you beat it when it's cold or not......Now if you had a solid roller like we run in race motors with a triple spring than yes it can make a difference.....But there is NO comparision...We run 300-450lbs on the "seat" and can go up to 1150lbs. over the "nose". The springs your talking about only have a 105lbs. at the "seat".
    Something is VERY WRONG!!!!!!
    leon iowa
    Quote Originally Posted by LS2Tuner View Post
    I checked them for coil bind and that is fine. I used the stock pushrods this time and not the 7.425 length. I have drove the car for longer than before with no problems. I kinda think the springs were not the 918 springs or if they were they must of been rejects. They didn't even look the same as all of the other 918 springs out there.
  1. How bad could it be - Broken valve spring
    By Intrepidman in forum General Help
    Last Post: 07-23-2010, 01:07 PM
  2. Valve cover gaskets, Valve Springs, Timing Gasket
    By Dewman in forum Parts For Sale / Trade
    Last Post: 01-22-2010, 08:14 PM
  3. Help: Broken Valve Spring
    By David Q in forum Corvette
    Last Post: 09-16-2009, 12:46 PM
  4. valve springs,HAL struts and springs,grannatelli lid
    By nosty1 in forum Parts For Sale / Trade
    Last Post: 07-25-2007, 05:23 PM
  5. struts/springs,lid,ls6 valve springs,F-body fuel pump hotwire kit
    Last Post: 06-30-2007, 03:33 AM
