Results 1 to 10 of 10
Thread: Panhard Bar
10-31-2006, 04:55 PM #1Member
- EL PASO TX.
RED- 1998 CAMARO Z28
Panhard Bar
I Have A Camaro Z28 5.7 And I Dont Intend To Lower The Car .
Should I Still Get The Adjustable Panhard Bar?
And What Its The Diference Vs Stock One?
Thanks
10-31-2006, 05:13 PM #2
Well, any aftermarket panhard bar would be better than stock. The stock one is just a stamped piece of steel. Aftermarket ones are solid. AND, if you EVER plan on lowering it later...the adjustable one will allow you to re-center the rear wheels.
11-01-2006, 08:29 AM #3Member
- EL PASO TX.
So Wich One Would Be Better For No Lowered Car Adjustable Or No Adjustable? Like I Said No Lowering Plans. The Money Its No A Problem There Its No Such A Diference In Price
11-01-2006, 10:06 AM #4
Well, if you never plan on lowering the car, AND after careful inspection the car's rear end currently is square with the body, then I would go with a non-adjustable bar. Again, any aftermarket bar is better than the stock crapper.
11-01-2006, 03:07 PM #5
I suggest a single adjustable bar. Even if you do not plan to lower the car, it will help to fit larger tires if you ever go that route. Also the rear end is not 100% square from the factory. Any panhard bar is an upgrade over stock with these cars.
11-01-2006, 03:52 PM #6
go with the adjustable. even from the factory, the rears are not centered.
11-08-2006, 03:03 PM #7
anyone made their own? http://www.jonaadland.com/Z28/Mods/PHB/AluminumPHB.html
11-16-2006, 07:36 PM #8Junior Member
- Texas
Black- 2002 WS6 Trans Am
What's better? Rod ends or poly bushings?
11-19-2006, 08:30 AM #9KWK N NUF
- Mar 2006
- Arlington Heights, Illinois
NBM- 2001 Trans Am WS6
I am told rod ends atleast in the long run. I was talking w/ the guy from Strano, and he said if the bushing goes bad you cant really just get a new bushing for it you need to replace the PHB. But if the rod end goes bad, you can change it out quite easily. Id say just spend the extra money and get the one w/ double rod-ends.
Pacesetter Headers & ORY, Magnaflow Catback, P&P TB, Koni SA Shocks, Strano Lowering Springs, TSP228R, PRC Dual Valve Springs, LS6 Ported Oil Pump, Vig. 3200 Stall, TransGo Shift Kit, Trans Cooler, Spohn Panhard Bar, UMI Rear LCA's, Relocation brackets, Torque Arm SFC. 411 hp / 386 ft/tq
11-26-2006, 05:21 PM #10
You can put new bushings in one.
Wanted: STB, Panhard, LCA's for 02 SS
By Ranz SS in forum Parts Wanted / TradeReplies: 2Last Post: 10-18-2009, 07:13 AM -
panhard rod
By c5z28 in forum Parts For Sale / TradeReplies: 2Last Post: 07-28-2009, 07:40 PM -
Slp lid and panhard bar
By whiteta in forum Parts Wanted / TradeReplies: 10Last Post: 10-23-2007, 11:25 AM -
slp panhard bar
By Nasty TA in forum Parts For Sale / TradeReplies: 1Last Post: 09-05-2007, 07:50 AM -
Panhard
By camarostripes96 in forum Firebird / WS6Replies: 2Last Post: 08-24-2006, 11:48 AM
