Results 1 to 19 of 19
    MSG Crusty SPECOPS94's Avatar
    NC
    Limited Edition #1242
    2002 Camaro SS LE
    Headlight Cleaning
    My headlights have now developed a haze on, or in, them. Any advice on what to use in order to clean them?
    detail king 2001somws6's Avatar
    ORLANDO,FL
    SUNSET ORANGE
    2001 PONTIAC TRANS AM WS6
    Meguiars plastix. FTW
    NC
    2002 Camaro SS LE
    So I assume that, although the haze appears to be internal, it is actually external? I haven't paid much attention to it until my last show and it really bothers me. What causes the haze to appear on the lens? Strange...
    Member 97PredatorTA's Avatar
    Tinley Park, IL
    '97 Trans Am
    If its real bad, follow this link...
    http://www.ls1tech.com/forums/showthread.php?t=157192
    Otherwise try plastix or even just buffing it with some light buffing compound.
    ORLANDO,FL
    SUNSET ORANGE
    Its the plastic that they use. I happens to alot of cars. But if it gets too bad wet sanding is the next step or replacement.
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Quote Originally Posted by 2001somws6 View Post
    Agreed. Its an excellent product, it cleans just about any clear plastic as long as it isn't physically damaged/pitted/ect.
    NC
    2002 Camaro SS LE
    I'm enroute to the auto store. Thanks guys I really appreicte it. The car looks pretty good but I HATE the hue and it doesn't help me at the car shows!
    Mike
    3rd recommendation, stuff works near miracles
    Painted manta stripe
    NC
    2002 Camaro SS LE
    Thanks again. Waitting to get home tonight to try it out!
    Mike
    Seaford
    2001 Trans Am
    i have heard if you use the shit like gojo that you use to clean your hands with after a dirty day at the shop, that will take the haze out
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    I use Zaino Plastic cleaner and my lights still look good.
    ruff ruff rotwiler's Avatar
    WA State
    LT's, 3400 stall, FIPK,CB
    2002 Z28
    Once they are really bad, I would look into just buying new headlights. I have spent alot of money on another car I had and never did look great, yes it made them look better, but never like new. I used special polish, buffer etc... When I messed up my headlights on the z28, I just bought the halo lights. Was cheaper than the stock ones and I liked the halo look. I haven't looked into the z28 lights to polish them since my past attempts failed, but most lights have a protective coating in the lense and once this is hazy, then there is no real way to fix it unless the coating is stripped off, then the actual lense will haze if not kept up.
    ORLANDO,FL
    SUNSET ORANGE
    I saw on pfyc (partsforyourcar.com) has a item like the clear bra for you headlights.
    alabama
    Gray
    2012 Challenger R/T
    if you have new ones , like my 05 ...What is the best thing to keep them looking good ..???
    I would suggest the Zaino plastic cleaner
    Member ProwlerZ's Avatar
    Myrtle Beach
    2002 Z28
    It's caused from UV exposure, and there are lots of products that can fix it, PlastiX being my favored.
    If they're real bad, you should just pick up a kit of headlight restorer from an auto store, like $15-20 and it'll come with the proper grain sand paper, polish, and sealer. From what I've seen, it gets it right back to normal.
    She's baaaaaccccck...
    '02 Z/28 M6 Hardtop
    Jenks/Tulsa
    Light Pewter Metallic
    y2k 8-cylinder catfish
    Will it help with mild pitting in the plastic too?
    2000 Chevrolet Camaro Z28 A4 - Light Pewter Metallic
    Direct Flo lid, SLP Loudmouth, Bassani Offroad Y-Pipe, BMR strut tower brace, BMR subframe connectors, shift points tune and !EGR
    2011 Kia Forte EX A6 Sportmatic - Titanium Silver Metallic
    Senior Member Z06-Goose's Avatar
    Colorado
    Avus Silver
    2007 Audi RS4
    Another vote for Meguiar's PlastX. It works real good on tail lights. On headlights it requires a bit more work. Another stuff that works very effectively on the headlights is the Novus 1-2-3 system. I haven't tried Zaino glass cleaner
    For all you zaino lovers, I hear Z2 works great on glass too. It can be used to protect your glass and aluminum wheels. I personally use RejeX paint sealant. Generally these days, a paint sealant can be used pretty much on other areas besides just paint; glass, metal, etc...
    Goose
    Colorado
    Avus Silver
    2007 Audi RS4
    Generally speaking, when it comes down to glass, and plastic, if you can feel the scratch with your fingernails, it's too deep to remove. You may find products that may level the imperfection a little bit more so on plastic than it would on glass, but still it's almost impossible to fix.
    If it's mild you may be able to reduce the damage a little bit. PlastX has done a good job on plastic for me on mid surface swirls, and very mild scratches. You need to work it in until hazed, and repeat until you start to see improvements
  1. Question: top cleaning
    By REVNORR82 in forum Convertible
    Last Post: 07-05-2012, 04:50 AM
  2. cleaning under the car
    By Berger21 in forum Showcar and Detailing
    Last Post: 07-18-2007, 06:02 PM
  3. Cleaning headlight covers
    By flyinlo2288 in forum General Help
    Last Post: 05-19-2007, 12:22 AM
  4. Cleaning Air Mss
    By RANSTRANSAM in forum General Help
    Last Post: 03-20-2007, 10:55 PM
  5. Cleaning out!
    By blackbird04 in forum Parts For Sale / Trade
    Last Post: 07-26-2006, 06:56 AM
