    Junior Member vinnie311's Avatar
    New York
    Blog Entries
    2
    pewter
    2000 Trans Am
    3rd and 4th gear grinding?
    hey my clutch seems to be grinding pretty badly when you put it into 3rd or 4th gear. the rest of the gears are fine. and once in a while, only happened like twice the shifter was stuck in 3rd gear and it took a while to get out. put a new clutch master in and checked the slave cylinder. think i need a new trans?
    metro Detroit area
    Search is your friend. 3/4 fork bending/jump out/ stuck in gear are well known issues. Get an iron 3/4 fork.
    metro Detroit area
    BTW its not your clutch thats grinding, its your trans.
    Dallas, TX.
    2002 Camaro SS
    torque converter
    It sounds like your torque converter is bent. Try replacing that.
    Got Juice? Nasty TA's Avatar
    Knoxville, TN
    2002 Trans Am WS6
    You have a bad 3/4 sincro. Yo uhave probly broken or worn down the dogs and it is causing the grinding. You need to order a 3/4 sincro assmbley, 3/4 Block rings and you should be fine. If you sre hard on it i recomend upgrading to a steel 3/4 shift fort, billet inserts for the 3/4 sincro assmbley and getting brass shift fork pads. You can get all this from D and D performance for about 350.00 www.ddperformance.com . plus the money to get the tranny taken apart and put back together. I 've used them for all my customers tranny's and also in mine. If your tranny has over 100,000 miles on it i recomend getting a rebuild kit from thme as well. It will save you having to go back in their again. If you are going to try to tackle this on your own, it is a big job and not for the inexperienced. If you get a part out of place or not lined up properly you will ruin all that you have done, not to scare you it can be done. I did my first one by my self with only the rebuild manual. Hope this helps feel free to ask me anything else.
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    Quote Originally Posted by jpick1353 View Post
    tq converters are in autos..his is a manual.
    Shepherd, Michigan
    98' trans am
    yea it sounds like a bent 3-4 fork..but it could also be the syncros
    New York
    Blog Entries
    2
    pewter
    2000 Trans Am
    yeah i meant my gears grinding not my clutch idk why i said that syncros?
    Junior Member josh110781's Avatar
    harrison twp. MI.
    2000 trans am WS6
    i have the same problem with 3rd and 4th gear grinding but its only under hard acceleration. so is it most likely the syncros or could it be something else
  1. Help: Headlight Gear Grinding
    By Ant71130 in forum Firebird / WS6
    Last Post: 05-21-2011, 07:56 AM
  2. Gear grinding
    By Ironwolf in forum Manual Transmission
    Last Post: 01-11-2010, 08:45 PM
  3. Grinding going into Second gear
    By matt333cars in forum Manual Transmission
    Last Post: 09-05-2008, 12:38 PM
  4. grinding 3rd gear?
    By hutch1999 in forum Firebird / WS6
    Last Post: 03-01-2007, 05:44 PM
  5. Grinding and locking in 3-4 gear
    By Warwick in forum Manual Transmission
    Last Post: 06-23-2006, 05:08 PM
