Thread: 15" wheel brake calipers?
10-26-2006, 09:11 AM #1
When I race I change to the 15" Weld wheels but that required me to grind down my calipers to allow the wheels to fit without rubbing. I do still drive the car on the street from time to time but is there a good caliper replacement that actually is designed to work with 15" wheels and is not a drag only? I hate to buy Baer calipers to grind down a 1200 or more set of calipers. Thanks Ya'll!
98 T/A: HPE 5.3 Heads, 238/242 113 cam, Kooks 1 7/8 stepped LT headers, Custom Y pipe, Cut out, Borla, NW 90MM TB, FAST 90MM Intake, TB Bypass, Under Drive Power steering and Crank, 150 Dry NOS, Yella Terra rockers, 3400 TC, HPE tuning,
10-28-2006, 06:33 PM #2
The Strange rears will fit but no E brake.
10-28-2006, 06:33 PM #3
get some LT1 rear calipers. kinda going backwards, but you won't have to grind. then again, you have already ground the calipers down.
10-30-2006, 06:06 AM #4
Yea, I was sort of hoping for a better caliper than I currently have with stock but I am stopping and the ground ones will do. Thanks for your help though!
Parking Brake "Brake" light not turning on
By Questioner in forum Firebird / WS6Replies: 1Last Post: 11-05-2015, 06:52 AM -
Brake calipers
By SactownHuskers in forum Appearance SectionReplies: 13Last Post: 03-27-2010, 04:35 AM -
Will 16" Wheels clear '02 SS Brake calipers..
By Stevenix in forum Wheels and TiresReplies: 6Last Post: 08-11-2009, 03:15 AM -
Question: Brake Calipers
By SSmoke in forum Suspension and HandlingReplies: 0Last Post: 05-07-2008, 05:55 PM -
FS: Z06 big brake kit-used calipers WITH bracket new 13" rotors, new pads *ebay link*
By 3.8T in forum Parts For Sale / TradeReplies: 0Last Post: 11-13-2006, 04:49 AM
