    Member since 1998 DarthD's Avatar
    Seguin, Texas
    Black ASC#7564 May11,2001
    2001 Trans Am WS6
    Does GM have an official maximum power rating for a stock block?
    The new GMPP LSX iron block is good for up to 2500 hp.
    Is there an official rating from GM on how much power a stock aluminum block and stock iron block can handle?
    Is there an official GM rating for the Gen 1 and 2 blocks?
    I tried search but all I can find are people's opinions on what a block may be able to handle. I would like to know the "official" rating.
    Thanks
    Alcohol Injected PaganEgyptian's Avatar
    Knoxville,Tn
    1999 Pontiac Firebird
    I havent heard an official number probably becuase GM doesnt have one themselves. I hate to say it, but QC on LS1 engines are chit. the ratating assembly tolerances out of Mexico are nightmarish. Eagle isnt what is used to be. That why LS1 are king of bearing spinners. They are all different in quality, just like the blocks. My friend had a defective LS1 block in his 2000 C5 and it popped at around 1100HP I think due to a bad casting spot in one of the cylinders. So if it holds that much being defective, I would say 80% of that would be ok within a saftey margin. -Tim
    Member GA Country Boy's Avatar
    Aug 2006
    Cumming, GA
    Metallic Red
    2002 Corvette Coupe
    I've also never heard a factory come out and say "you can push our blocks to XXXXHP before it blows". Their only concern is being able to handle what it was designed for with a good safety margin. I've never had a major concern with the block...it's always been the head gaskets and the heads (assuming you've replaced the internals with forged pieces). But anytime you start pushing a motor way beyond what it was intended for everything has to be done right.
    Michael
    In GA waving from '02 C5 LS1, Z51, D1SC, 60lb injectors,RPM level 5-4L60E, 3:42, Yank 3600, QA1-12 ways, MTI long headers, high flow cats, Borlas, Wilwood, 603rwhp, 542rwtq.(DynoJet 248-C) [email protected] on street tires, Race Weight 3,640 lbs
    Ugly but well hung, A-10 SS#1531's Avatar
    Eglin AFB, FL
    1998 Camaro SS M6 Hardtop
    Quote Originally Posted by PaganEgyptian View Post
    If my LS1 block can handle just under 1100hp before it blows, I wouldn't consider than defective. That's over 3 times the stock hp.
  1. 2013 Shelby Gets it's official HP rating from Ford
    By redbird555 in forum Almost Anything Goes
    Last Post: 05-21-2012, 01:09 PM
  2. Maximum Power from a 30th Ann Trans Am
    By SnakesandArrows in forum New Member Introductions
    Last Post: 07-16-2008, 06:47 PM
  3. Replies: 0
    Last Post: 02-07-2008, 10:30 PM
  4. Replies: 0
  5. How much power can stock LS1 block safely handle?
    By svtben in forum Forced Induction
    Last Post: 03-29-2007, 03:00 PM
