Results 1 to 19 of 19
Thread: LS6 cylinder heads on LS1
10-24-2006, 08:40 AM #1
How would a set of LS6 cylinder heads perform on a (1999) LS1. I plan on getting a cam to go with the heads.
10-24-2006, 08:43 AM #2Slow'er'Ass
- Thornton, CO
Are you looking to save money with them??
Is that why you are looking at the LS6 heads?? Cheap?
Personally, I can't see doing all that head swap work to put a stock-like head on a car. Patriot makes some fine heads that will outperform the stock LS6 heads for $1100 or so.
What cam are you looking at?
10-24-2006, 11:29 AM #3Rodzilla Tha Cavity Filla
- Sep 2006
- San DEEEE Eggo
teal- 99 Z28 with an SS complex
yeah. How much are you planning on spending for the head and cam set up.
10-24-2006, 12:18 PM #4
The patriot ore eigther the 5.3L heads or LS6 heads. then they take them and port polish them up.
If you wanted todo it in stages per say. you could get the LS6 heads have them for a bit them have them P&P.
The differnace with the patriot is you get it all done at once and it comes with everything valves and what not.
For myself i will be getting a 241 casting(LS6) then do a minor P&P on them at a later date. The LS6 stock heads form will flow fine for me and the HP that I want to put at the RW with the CAM that I am looking at.
10-24-2006, 12:31 PM #5Junior Member
- Ft. Lauderdale, Fl.
white- '96 C-1500
LS6 Heads?
On a stock 2001 Camaro SS LS1, without a cam(I have 1.8 Crane rockers), what would the gains be? Thanks, Gar
10-24-2006, 01:03 PM #6Slow'er'Ass
- Thornton, CO
15 RWHP maybe.
10-24-2006, 05:00 PM #7
what abouy port and polished LS6 heads with a cam. I don't know what cam I want but would it be capable of supporting 375 to 400 horsepower?
10-24-2006, 05:33 PM #8
yea. P&P on the cylinder heads, a good cam like the TR224, headers, TB, and intake... about 400 RWHP
10-25-2006, 03:40 AM #9
i went with the ls6 heads casting #243 and a 237/242, 113 lsa, .603,.609 cam. i had the heads cnc ported with a valve job and im extremely happy with them.
10-25-2006, 07:22 AM #10Ratdaddy07Guest
Same here, LS6 P&P 228/228 .580/.580 114 LSA extremely happy with the power.
10-25-2006, 08:26 AM #11
Awesome! Thats exactly what I wanted to here. I want to have around 400 horsepower on a budget and still pass Pennsylvania emissions.
What size throttle body should I go with?
10-25-2006, 08:28 AM #12
I heard Ed Vert has a good cam and keeps his emmisions leagal. I'll see if i can find the post that i read it from.
10-25-2006, 08:34 AM #13
Here we go
Here is the link that takes you to a CAM guide(READ READ READ).
http://www.ls1tech.com/forums/showthread.php?t=327734
To save time here is the paragraph:
If you have the sniffer for emissions either go with the cam of your choice and pray you find a good enough tuner and have luck on your side or choose a smog friendly grind. Keep the overlap in check, the more negative overlap @ .050 the easier it will be to pass. Here is Ed's (Ed Vert's) Cali smog sheet his tr224 114 which has negative 4* overlap @ .050.
10-25-2006, 11:58 AM #14
Thanks. BIG HELP!!!
10-27-2006, 02:37 PM #15Bad habbit- Smoking Fords
- South Florida
Sunset Orange Metallic- 2001 Camaro SS
10-30-2006, 01:28 PM #16Junior Member
- Oct 2006
- Chicago
pulled this from another thread:
fix the space in the link to make it work, wouldn't let me post it since i don't have 5 posts.CNC ported, CNC valve job LS6 heads brand new from TSP for $899 Check out specs and videos. Dyno proves 50 rwhp
ht tps://texas-speed.com/shop/item.as...d=649&catid=20
10-30-2006, 01:41 PM #17
Good price for what SEEMS like a comperable type to the Patriot set-up
11-02-2006, 11:14 AM #18Junior Member
- Oct 2006
- Seaford
Black- 2001 Trans Am
11-16-2006, 07:59 AM #19
i came across a good deal on brand new factory ls6 heads that are slightly ported. i also swapped in a 04 ls6 cam with it. the car runs strong. i realize there are more powerful setups, but i came across a good deal and i wanted the car to still be reliable. i liked the idea of using gm parts also.
Question: Ls6 cylinder heads
By RollTide696 in forum Internal EngineReplies: 8Last Post: 07-11-2015, 06:32 PM -
L92 Cylinder Heads Install - It’s All In Your Heads
By Ed Blown Vert in forum Camaro / SSReplies: 0Last Post: 05-24-2011, 07:10 AM -
Affordable Cylinder Heads - E-Street Heads
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 07-14-2009, 01:20 AM -
T-rex & Heads Cylinder
By fahadss in forum Internal EngineReplies: 0Last Post: 07-17-2006, 07:16 AM
