Thread: losing fuel pressure
10-24-2006, 05:29 AM #1Junior Member
- May 2006
- citrus heights ca
red- 98 z28
I've got a 98 z28, when I shut the engine off the fuel pressure bleeds off at the fuel pump, considering what a pain that would be to change, I was wondering if anybody knows of some sort of check valve that could be placed inline around the fuel filter? Seems like that would be a lot cheaper & easier.........
Thanks!
10-24-2006, 05:56 AM #2
It will bleed off some but how fast does it bleed off? Is is just 5 or ten pounds or is it all bleeding off?
10-25-2006, 03:02 PM #3Junior Member
- May 2006
- citrus heights ca
red- 98 z28
I took it to the dealer, they say it went from 60 psi to 0 in 10 seconds - my feeling is that it doesn't always do that, usually starts right up first thing in the morning, most of the problem is when it's hot outside....doesn't seem to have the problem as much now that we are past summer temps. BTW, they ONLY want $1100 to replace the pump
10-26-2006, 01:35 PM #4Senior Member
- Jul 2005
- Jacksonville, FL
So after their diagnostics they're condemning the pump? $1100...ouch. There's a link here on replacing it by cutting an access panel on the rear deck - maybe you can get the pump cheaper (gmpartsdirect) and have a shop do the panel a lot cheaper. I'll find the link.
10-26-2006, 01:47 PM #5Senior Member
- Jul 2005
- Jacksonville, FL
10-26-2006, 04:47 PM #6Junior Member
- May 2006
- citrus heights ca
red- 98 z28
Yeah I've seen that, thank you for checking, something about cutting a hole through sheet metal, sparks, gas tank, fuel lines nearby just doesn't feel right.......seems like if I could just find a check valve, put it inline with the filter I would be good to go without blowing myself up in the process
Clutch pedal losing pressure?
By redbird555 in forum Manual TransmissionReplies: 0Last Post: 06-12-2012, 08:43 AM -
clutch losing pressure
By speedaddict in forum Manual TransmissionReplies: 1Last Post: 01-10-2007, 10:28 AM -
losing clutch pressure
By kgross in forum Manual TransmissionReplies: 5Last Post: 05-09-2006, 01:40 PM -
What fuel pressure should I set my fuel pressure safety switch at?
By JAvery20 in forum NitrousReplies: 3Last Post: 04-01-2006, 03:59 PM
