Results 1 to 20 of 48
Thread: oil ????? synthetic???
10-23-2006, 04:05 PM #1
Hey guys, we just picked up a 98 TA And I was wondering what oil you guys use, I know in my vette, with the ls1 motor, requires synthetic, but in the TA manual it doest mention to use synthetic, I thought that was kind of strange since the vette needs it I would have thought the same for TA, here's a little eye candy for ya, thanks Ozzie
10-23-2006, 04:07 PM #2
Castrol Syntec 10W30 is my choice and have real good luck in several cars already.
2002 Sunset Orange TransAm 6 spd.
http://www.mustangmods.com/data/1327/dadsigpic2.jpg
10-23-2006, 04:56 PM #3
Do they come from the factory with synthetic?
10-23-2006, 08:02 PM #4
My 01 TA did not come with Mobil 1. Your Vette does not require it but it's not a bad idea. I use Redline 10W30.
10-23-2006, 08:59 PM #5
anybody try out that royal purple stuff? i was thinking of switching and trying it out. i now use mobil 1 synthetic.
10-26-2006, 01:38 PM #6
- Oct 2006
- SW TEXAS
WHITE- 1998 TRANS AM
10-26-2006, 01:44 PM #7
- Sep 2006
- Canby, Oregon
Pewter- 1999 Camaro SS-M6 #1775
I run Valvoline performance full synthetic 10W-30 in mine and it works great.
12.6 at 112
10-26-2006, 02:31 PM #8
10-26-2006, 04:34 PM #9
- Jul 2006
- Greene, Iowa
Red- 99 Chevrolet Camaro Z-28
i used to run quaker state 10w-30 in my maro. starting to hear ticking on start up (oil was breaking down too fast) went to a quaker state 10w-30 synthetic blend. went longer till the ticking on start up (still breaking down) and it was just starting to get a fil, of metal on the drain plug. so i stepped up to mobil 1 full synthetic. 40 bucks an oil change now, but no more ticking, and no more metal film on the drain plug. and still comes out pretty clean after changed
10-27-2006, 08:38 AM #10
- Jun 2006
- USA
- 2001 WS6, 2003 SRT4(sold)
I've been reading a lot of good things about German Castrol Synthetic 0W-30... only trick is it's tough to find and you have to read the back of the bottle to be sure it's German made, because the USA formulas don't work nearly as well.
10-27-2006, 09:21 AM #11
Just switched to redline myself. From what i have read they are great. Also have EXCELLENT customer service!!!! Definatley recommend.
10-27-2006, 09:48 AM #12
- Retired Outlaw Sum Bitch
IT DOES NOT REQUIRE SYNTHETIC OIL!!!!!!!!!!!!!!!!!!!!!!
It recommends Mobil1. Called a marketing agreement.
Or a pimping agreement. Your warranty requires you to utilize API certified oils within viscosity recommended. That would include WalMart SuperTech oils.
GM does not require any motor it makes to utilize synthetic oil.
10-29-2006, 07:34 PM #13
10-29-2006, 07:42 PM #14
- Jan 2006
- Shepherd, Michigan
any body use 0W????sarge dont you?
10-29-2006, 08:03 PM #15
- Thornton, CO
I use the basics.
5w-30 Mobil 1.2008 Trailblazer SS
Lowered, HID's, tinted.
11-06-2006, 11:06 AM #16
- Columbus, OH
Pewter Metallic- 2002 Firebird Formula
5W-30 Mobil 1 Full synthetic ... used it since mile 1.
Pewter Metallic | Ebony cloth
K&N filter | Magnaflow | Eurolights Xenon kit | Clear LED Side Markers
11-06-2006, 11:30 AM #17
Penzoil 5w-30 Platinum, syntetic oil, change every 5k.. if you race it almost every day, I'd do every 3-4K miles oil change.
11-06-2006, 04:20 PM #18
i use mobil 1 in everything except my dodge it gets rotella
11-09-2006, 08:38 PM #19
I noticed the late model Firehawks recommend Mobile 1. I use Mobile 1 10W-30 . Change the filter every time the engine oil light comes on and oil ever other time, total about 7k miles between oil changes, according to independent tests Mobile 1 should be good for about 10K miles between changes. The filter I use is Purolator Pure One.
11-10-2006, 05:33 AM #20
Synthetic oil after 100k
By johnfin in forum Internal EngineReplies: 4Last Post: 08-18-2016, 06:34 AM -
Best Synthetic?
By Sarge in forum Almost Anything GoesReplies: 2Last Post: 05-22-2009, 05:38 AM -
when is it too late to use synthetic oil
By jinouk67 in forum GTOReplies: 4Last Post: 07-01-2007, 03:17 PM -
Mobil1 100% Synthetic Not
By Sarge in forum General HelpReplies: 105Last Post: 06-02-2007, 06:59 PM -
Synthetic ATF Ok or Not?
By sfletch2000 in forum Manual TransmissionReplies: 7Last Post: 05-24-2007, 12:42 PM
