Thread: questions about cam install
10-19-2006, 07:01 AM #1
- Jul 2006
- indiana
black, 05 Roush- black, 99 T/A WS.6
I am interested in getting a cam not sure on which one yet thinking of TR or TSP but was wondering what else i would need to support it. Such as lifters, pushrods and whatever else, can you guys tell me what I should get.
1999 T/A WS6 Black-------SOLD
05 mustang Roush sport;
DOB manifold, m122 SC, 47lb injectors, gt500 TB, roush TVS CAI, Detroit rocker SC grind camshafts, Mac LTs, off road x, roush off road mufflers, roush short throw shifter, kenne bell BAP, Brenspeed 93 octane tune. 479rwhp 436ftlbs SAE.
10-19-2006, 07:08 AM #2
when I swapped cams, I did the following:
Comp 224/224 .581/.581 112lsa
Ls2 timing chain
Ls6 Oil pump (ported and shimmed)
Patriot Dual Gold Springs
Titanium retainers
Spring Bases
Pushrods
I chose not to do lifters since I only have 30,xxx on the car. Stock lifters are fine depending on mileage and the lift of the new cam. it's not a necessary upgrade, neither are the spring bases, but since I had all the pieces I used them all...2018 CTS-V: °°668rwhp/658rwtq°°
2013 ZL1: °°590rwhp/576rwtq°°
10-19-2006, 08:00 AM #3
- Jul 2006
- indiana
I have 70k mi on mine, think I need new lifters and retainers?
10-19-2006, 08:26 AM #4
- Jul 2006
- indiana
really thinking of getting a cam package from TSP including their Magic stick 4. has anyone purchased this cam package yet? How well does it work, would you say it would be too much for a DD if so what would be a good cam for a DD.
10-19-2006, 08:53 AM #5
i think your stock lifters will fine for anything under .600 lift. however, don't hold me to that. call TSP and they would be able to point you in the right direction.
I am not sure what the cam specs are for the MS4. I thought it was either the high 230 range or low 240 range. for a DD it is possible but idle and off idle drivability would be a bit more rough than some may prefer. usually for a DD if the cam is around 228 or 230 is about as high as you would want to go. also, I would stay away from anything lower than a 112 lsa, esp the bigger cam size you select.
10-19-2006, 09:05 AM #6
I used this setup on my 2001 WS6.
TSP 231/237 .598/.595 112 LSA CAMSHAFT
PATRIOT GOLD VALVE SPRINGS (GOOD TO .650 LIFT)
LUNATI HARDEND PUSH RODS (STOCK LENGTH)
Works great with stock heads, and even better with a good set of AFR heads.
10-19-2006, 09:54 AM #7
- Jul 2006
- indiana
thanks for the info guys. I am now looking at TSP 228R cam the specs are:
228/228 .588/.588 112lsa. along with i would get TSP hardened chromoly pushrods and comp cams 918 spring kit (rated at .600lift) is this a streetable application, I have stock heads. This isnt going to be too much for my rearend is it. Also would it be too much to have a converter/stall installed at the same time, dont want to destroy my stock rear end just yet if its avoidable.Last edited by Wheeler99WS6; 10-19-2006 at 10:33 AM. Reason: forgot the specs
10-19-2006, 11:15 AM #8
that cam will work just fine, very streetable. you will have no problems at all. remember to get a tune after getting your cam installed. it will not hurt your rearend and yes a TQ converter installed at the same time would benefit you greatly. however, since I have an M6, I can't help you there.
NHRA Formula will be able to offer up some tips in that area I'm sure...
10-20-2006, 08:44 AM #9
- Jul 2006
- indiana
sweet thanks
Cam install questions
By MIKEY'S 2002 TA in forum Internal EngineReplies: 16Last Post: 01-25-2010, 05:55 AM -
LS1 Hot Cam Install And questions!
By pilot13blackcat in forum Internal EngineReplies: 13Last Post: 04-14-2008, 08:55 AM -
Want to install l92/l76. But have questions about the block
By got-a-ls1 in forum Internal EngineReplies: 1Last Post: 04-23-2007, 06:39 PM -
By brad22486 in forum Internal EngineReplies: 15Last Post: 08-31-2006, 06:15 PM -
Install questions, please help!
By RAWPWR3 in forum General HelpReplies: 5Last Post: 11-04-2005, 05:37 PM
