Results 1 to 20 of 37
    Member Jon7I2's Avatar
    Chicago
    99 Formula M6
    2nd gear downshift near 100MPH. HELP!!!
    Hey guys, I really need your help here. Ok, I was driving down a wide open street and I was ahead of all the traffic, so I decided to down shift and hit it. I was in 5th doing about 60mph, and I downshifted to fourth, realizing I still wasn’t in the power band, I shifted to 3rd. I got into 3rd fine, and climbed up the RPM scale until I was at about 5600-5700 RPM’s when I went to shift hard into 4th. However, for some reason (and I still do not know how) I shifted into 2nd. The whole rear-end locked up, as quickly as I could, I shifted into neutral. The check gauges light came on (not SES light, though), and I shut the car off at the next stop light (almost immediately after). When I went to start it up, it hesitated for a second and then started up. To my extreme surprise everything seemed to be alright. The reared wasn’t blown, and the car was actually driving. As soon as I could, I pulled over and popped the hood just to check everything, and I heard a distinctive tapping noise coming from the block. I pushed the throttle body chain and the tapping sped up, relative to that. What the hell did I do? What is this noise? How should I go about fixing this? Also, 2nd gear felt longer/looser than it ever did, after this incident. Will I need substantial transmission work or what? Please let me know anything you can about any part of this, it would be a huge help. Thanks a lot guys.
    old timer blue02Z's Avatar
    2002 Z28
    well, hopefully your rev-limiter stopped you from floating your valves, but if it didnt, your pistons could of hit your valves and f'd up something to that nature. maybe-someone correct me if i'm wrong- but you could have jumped timing.
    Member Phlash_riot's Avatar
    Aug 2006
    San Diego
    Midnight Blue
    1999 T/A
    Well did the some thing...TWICE!!!!. once when i first got the car(the same day) and the second at the track. scared the crap out of me.. then that horrible ticking... i thought it was all over for me the first time that i heard it.
    But all is not lost. it is most likely a push rod - EASY FIX
    For this process you will need to get a couple tools:
    1. a engine stethoscope - any pep boys, auto zone, O Riley's.. etc etc
    2. 6 pack of your favorite beer - any liquor store and some grocery stores.
    find on which side the ticking is coming from with the stethoscope. You really need to use it too. I thought my ticking was coming from the passenger side but the scope said driver... and what do you know it was. the scope even told me which cylinder it was on.
    1. Remove your tower brace- if equipped
    2. remove the coil pack form the affected side
    3. relieve the fuel pressure at the shrader valve located at the end of the fuel rail. be sure to place rags around to catch the lost fuel...but it won't be much. i had maybe 1/8 of am ounce come out of mine.
    4. remove the fuel lines with the proper tool required.(I didn't have the tool nor know what tool to get. i worked with them still secured)
    5. remove the valve cover
    Now from there i removed the each of the rockers one by one. once one rocker was removed i pulled the push rod out.
    as soon as i pulled it out i marked the top end with a magic marker so that i could put it back in the way that it came out.
    check each rod for bends by rolling it on a piece of plate glass(i used a old fish tank on its side)
    The stock rod will all have a slight skip to the when rolling them as there are small burrs at the end from when the pressed the ends into the rods.
    You will pretty much know when you pull it out that it is bent by looking at it.
    if you find one that is bent go down to the dealer and get a new one for 17.88 or order one from pep boys and wait the one day it takes to come in for 5.23. you call on that.
    when installing a new push rod be sure to put assembly lube on the ends. be generous with it too. the lube is cheap. i put lube on all my push rods when i put them back in but I had nothing else better to do with the tube i have.
    once you have all that back together just torque down your rocker arms to the specific torque....off the top of my head i think it is 22ft lbs... but not sure. make sure that you are not on the valve "open" part of the came lob for the particular cylinder's rockers.
    For myself i tightened them all down to specified torque then turned the engine over till i got where one of the sets were fully closed then i re torqued. then turned engine over a bit more till the next one was fully closed and repeated till i was done. put the valve covers on and torque to 122in/lbs(11ft/lbs will do) and coil packs back on and you should be good to go.
    Hope this help. i got a new valve cover gasket but have been told that you can reuse the stock one.. your call on that. if you have any questions you can PM or reply thread.
    I just did this fix 2 weeks ago so it's still kinda fresh in my head.
    Chicago
    99 Formula M6
    Wow. Thanks a lot. I really didn't expect such a thourough anwser from anyone. So, you did it as well, and everything's ok? Except for the pushrod of course. Thats really good news to me, because i was expecting a whole list of things to be screwed up. How are your gears/ trans. after your similar experience, worse or no difference?
    my bet is bent pushrod(s)
    St. Louis
    02 z28
    most likely bent pushrod, pretty easy to check and change, pull off the coil packs, then the valve cover, loosen the rocker arms and rotate them out of the way, pull up the push rod then check to see if it is bent in any way. if not put it back in (i like to put a little oil on them when i put them in) line up the rocker arm and then tighten it down to the specific torque specs(i can't remember but i think it's like 21-22 ftlbs), keep going till you find the bent one, i'm betting it's a bent one, as soon as you change it the tapping should go away.
    edit, i just fully read plash riots post...his is more detailed but you get the point.
    if you need some push rods i have some laying around i could ship out.
    Tony
    02 Camaro Z28
    UltimateSR <-- Join it!
    Aug 2006
    San Diego
    Midnight Blue
    1999 T/A
    As far as my gears. I so no differance. shift just like it did before. luckily tires broke loose instead of something else breaking. had freind that did the same thing in his mustang and obliterated his tranny.
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    i'm about 99% sure its a bent pusrod..but man you are sooo lucky you didnt float the valves and screw alot more up..and your tranny..but yea good luck man ! tell us how it goes/ what was wrong.
    mods- suncoast creations hood with functional lt1 style airbox, ls6 intake, QTP longtube headers, QTP ORY, UMI SFC, Adj. LCA with relo brackets, UMI adj. panhard bar, Koni SA and strano springs,Torq Thrust M 17s 9.5 and 10.5 with nitto 555Rs, tuned by Frost
    Quote Originally Posted by Modulistic View Post
    sometimes you get owned, sometimes you own.
    SS#430 1 of 74 7camaro7's Avatar
    Nashville, TN
    02SS6spd VERT!
    one time I redlined 2nd and went to first too! Scared the shit out of me too. I've got no ticking though. I haven't shifted on a hard turn since hahaha!
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    Glad I bought a auto...i'm sure there's people out there that would just pawn their car off to some poor soul after a miss shift like that....basturds
    Chicago
    99 Formula M6
    Ok, it ended up being bent pushrods like you guys all said. 7 of them were bent, and 1 was tremendously bent. I mean, 1 of them had like 30-40 degree bend on it. The compression test came out good on the heads, so thats all good. All the pushrods have been replaced w/ chromoly ones so everything should be good. I barely drove the car at all after this happened (less than 25 miles) but is there anything else w/ the engine that could have been screwed up, besides the heads(cuz it was fine)? Thanks for all ur help guys.
    Member 98Z-28Camaro's Avatar
    Oklahoma City
    1998 Z-28 Camaro
    it depends on how high it revved when you shifted. If you lefted it in 2nd long enough for the motor to rev all the way up, then there could be more damage. No matter what your rev limiter is set at, if you lefted it in gear long enough for the motor exceed the factory rev limiter, it will pass the rev limiter and continue to climb because of the clutch being locked to both the flywheel and the transmission which is also locked to the rear end. So the rev limiter is only good if you are accelerating the motor through air and fuel combustion, it does no good if your rear tyres are turning the motor.
    But if it doesn't make any noise now then you are probably good to go.
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Quote Originally Posted by Jon7I2 View Post
    Glad to hear you found the problem. I'm sure you buried the tach right past 7 grand when you went into 2nd at that high of an RPM. I'm sure the bottom end of the motor can take it just fine, but like you found out, the valvetrain can't. I'm sure you also floated the valves, but I doubt they floated enough to make contact with the pistons, so it shouldn't be an issue.
    How it run after replacing the pushrods?? Any unusual noises??
    NJ
    SGM
    1998 Trans Am WS6
    Quote Originally Posted by blue02Z View Post
    As someone already explained, the rev limiter cannot stop the engine from going past the redline when its being forced by the speed of the drive wheels. The rev limiter only prevents over-rev by way of throttle application, since it can cut spark/fuel when the redline is reached. The engine was accelerated by the rear wheels, since the clutch engaged the trans to the engine. The wheels, rear, and driveshaft were spinning the output shaft at high speed, and since the trans was in 2nd gear, the input shaft was spinning much faster than the engines max RPM for 2nd gear.
    There is little change that the engine jumped timing, the LS1 has a double timing chain, not a stupid belt like a Honda. For that chain to jump it would either have to be very lose or just break completely, in which case the engine wouldn't run. Not something I would even consider worrying about
    Chicago
    99 Formula M6
    But, thats what im saying, if significant damage was done, redlining, then the cylinder would have hit the the valve and there would significant leakage. Right? Then the problem would only be the head, and nothing else?
    Chicago
    99 Formula M6
    Yeah, it seems to run fine now. I guess im just trying to make sure that there are no problems or potential problems i do not realize. But just by driving the car, it seems perfectly fine w/ the new pushrods.
    NJ
    SGM
    1998 Trans Am WS6
    No, there probably wouldn't be any "leakage", unless by leakage you mean intake and exhaust air entering the cylinders at the wrong times due to bent valves. In that case it would like like total shit, have no power, backfire, and sound horrible.
    If that were the case (unlikely by what you described), you probably need a new head as well as new pistons, since they would be damaged from the impact with the valves.
    Chicago
    99 Formula M6
    Oh ok, thanks. But i doubt that is a problem, because like u said that would be very noticable. and right now there is nothing noticably wrong w/ the car, so hopefully i got lucky, and need to move up to pro 5.0 to ensure this never never happens again.
    NJ
    SGM
    1998 Trans Am WS6
    Exactly
    I love my Pro 5.0, best shifter I've ever used. Took it to the track, shifted as fast as possible, and didn't miss one gear either run.
    Its got the most direct feel of any shifter, absolutely no rubberyness at all. Hard to miss gears when they are exactly where they should be and easy to find
    Dec 2004
    SS: NBM, tan top
    1998-SS, 2010 Jetta TDI
    "response to the first post"
    that must have scared the living SHIT out of you!!
  1. 90-100mph
    By 02ws6transam in forum Firebird / WS6
    Last Post: 10-27-2007, 10:50 AM
  2. downshift?
    By LETHALxLS1 in forum Automatic Transmission
    Last Post: 07-01-2007, 09:34 PM
  3. why won't my car downshift?
    By shady1504 in forum Automatic Transmission
    Last Post: 04-16-2006, 03:47 PM
  4. badass vid- go cart 100mph+ on the highway at night
    By whitelightnin99 in forum Almost Anything Goes
    Last Post: 03-05-2006, 05:51 AM
  5. Replies: 7
    Last Post: 08-09-2005, 09:52 PM
