Results 1 to 18 of 18
Thread: Gear Ratio
    #587 pipes_ta's Avatar
    Shorewood, Illinois
    2001 Pontiac Trans Am WS6
    Gear Ratio
    What is the stock gears in a 2001 pontiac trans am ws6 A4.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    depends. either 2.73 (GU2) or 3.23 (GU5). look on the driver's door for those RPO codes to see.
    Shorewood, Illinois
    ty
    thanks didnt know that
    orlando, fl
    2014 camaro 2ss/rs
    no problem.
    Vienna WV
    98 Trans Am
    I dont have a label on the drivers door. Anyway else I can tell if I have a gu5?
    Senior Member Hurley711's Avatar
    Earth
    414 RWHP 395 RWTQ
    00 Black Ram Air Trans Am
    Get some 3.73's and a nice stall and forget about what stock gears you have, you will thank us later after those 2 mods
    orlando, fl
    2014 camaro 2ss/rs
    Quote Originally Posted by daveb91 View Post
    look in glove box
    Vienna WV
    98 Trans Am
    look in glove box
    Nothing in glove box.
    Impounded YoMommasTA's Avatar
    ne pa
    would be on the drivers door,white label.Otherwise you are going to take the cover off and look if its a "REAL" ws6 it should be 3.42 with a auburn carrier i believe.non ws6 will be 2.73 with a torsen carrier.
    Virginia
    ws6 = 3.23 ta = 2.73
    Aug 2006
    Missouri
    94 Camaro Z28
    Only the 6-speeds had the 3.42 option.
    Autos could only come with the 2.73, 3.08, or 3.23 gears.
    And it doesn't matter if the car was a WS6 or regular TA, they could come with any gear ratio, unless its an auto (which didn't have 3.42, as mentioned earlier).
    GU2 Axle, Rear 2.73 Ratio
    GU3 auto tranny,
    GU4 Axle, Rear 3.08 Ratio
    GU5 Axle, Rear 3.23 Ratio
    GU6 Axle, Rear 3.42 Ratio
    G80 Axle, Rear Posi-traction (Limited Slip)
    93-02 RPO codes for f-bodies.
    Vienna WV
    98 Trans Am
    I really didnt mean to thread jack but i did have the same question. My car doesnt have a label on the drivers door and nothing in the glove box. Can someone maybe who has 3.23 tell me there rpms at a certain speed and gear then maybe I can find out that way?
    386HP 373TQ jwindbigler's Avatar
    San Diego...Michigan originally
    1999 Trans Am 5.7L
    I agree, just get some 3.73's. I put them in mine, and it made a heck of a difference.
    Feb 2006
    MD
    If you're sure its stock look at the driveshaft. 2.73 cars got a steel shaft, 3.23 cars got the aluminum shaft.
    Aug 2006
    Missouri
    94 Camaro Z28
    If you're really curious, jack the back end of your car up, and turn the back wheels by hand and count how many times the driveshaft turns for every revolution of the tire.
    ne pa
    pull the cover and look at the ring gear!
    Sep 2016
    Brooklyn
    Quote Originally Posted by BlackLT1Z28 View Post
    GU3 auto tranny,
    Lol nope not true I seen ws6 auto cars with 3.42 gears posi and l.slip Don't know where these people come up with this crap
    Sep 2010
    Bel Air, Maryland
    '02 Trans Am WS-6, 6M
    Quote Originally Posted by Carmine lucchese View Post
    The only way a an auto model would have a 3.42 gear set is if they either pulled an assembly off of a manual car, or changed the gear in their own diff'.
    From the factory, V8 autos only had a choice of 2.73 or 3.23. Manual V8's (post 1993) only had an option of the 3.42 gears.
  1. gear ratio's
    By Team Villan in forum Drivetrain
    Last Post: 07-28-2008, 10:32 AM
  2. Gear Ratio
    By TransAmFanatic in forum Drivetrain
    Last Post: 03-29-2008, 01:52 PM
  3. Gear ratio vs. take-off
    By slade8200 in forum Drivetrain
    Last Post: 04-14-2007, 05:24 PM
  4. Gear Ratio
    By enjun in forum Drivetrain
    Last Post: 01-15-2007, 12:57 AM
  5. 3.42 gear ratio
    By larryndog in forum Drivetrain
    Last Post: 10-04-2006, 12:45 PM
