Results 1 to 2 of 2
Thread: LS1 breaking point
10-07-2006, 05:22 PM #1Junior Member
- Oct 2006
- Toronto
LS1 breaking point
does anyone know how much hp the ls1 block can handle? i know internals are good for roughly 500hp, but after those are replaced whats the limits of the block? any help would be great thanks
10-08-2006, 06:19 AM #2
I recall reading in a post, that linked to a High Performance Pontiac or other magazine like that that said the aluminum block LS1 is good for up to 500 - 600 max. After that, you need to go to a cast iron 6.0l block and suggests dry sump oil pump. With that you can go to somewhere over 1400HP if you so desire.
I'm going from memory, so I suggest doing some searching and you should find a link to that article somewhere on here.
Breaking in 4.10's
By GottaHaveLS1 in forum DrivetrainReplies: 6Last Post: 05-21-2008, 02:14 AM -
Breaking out the UDM
By JonB in forum Showcar and DetailingReplies: 5Last Post: 03-28-2008, 07:09 PM -
Subframe Connectors - 2 Point vs. 3 Point...Advantage/Disadvantage
By midi_2001 in forum Suspension and HandlingReplies: 10Last Post: 12-06-2007, 11:24 AM -
SFC chromemoly2 point vs. 3 point
By Viprklr in forum Suspension and HandlingReplies: 4Last Post: 06-30-2007, 05:26 AM -
Army stretched to breaking point, report says
By BillyT in forum Political / Debate ForumReplies: 19Last Post: 02-06-2006, 07:14 PM
