Results 1 to 1 of 1
10-07-2006, 06:56 AM #1Gold Member
- Oct 2006
- Colorado Springs, Co
arctic white- 2000 trans am
newbie with clutch/trans problems
Hi everyone! this is my first 6spd. My clutch was acting up so I had it replaced. I have a total of about 10 miles on new one. I put a ram hdx clutch a ram billett steel flywheel and new GM slave cylinder, so the problem is my clutch starts engaging when the pedal is about a quarter of an inch of the ground and it makes it very hard to shift and going into reverse is even harder. I dont know much about manual trans. is it a bleed problem? Is there any way to adjust it? Do i need an adj. master cyl? Any advice that any one has would be appreciated.
Help: Clutch/Trans Problems?
By phoenixXIV in forum Manual TransmissionReplies: 1Last Post: 09-04-2011, 06:47 PM -
Help: 98 camaro vats problems and clutch/trans
By pk222 in forum V6Replies: 1Last Post: 08-11-2011, 08:32 AM -
clutch problems
By dzikusnj in forum Firebird / WS6Replies: 2Last Post: 04-14-2011, 09:05 PM -
Clutch Problems
By gameoverz28 in forum Manual TransmissionReplies: 2Last Post: 02-09-2010, 07:14 PM -
Had Clutch slave cyl, clutch master cyl, and Clutch kit installed now I got problems
By 7camaro7 in forum Manual TransmissionReplies: 21Last Post: 12-13-2007, 07:41 PM
