Results 1 to 10 of 10
    Georgia
    2014 Camaro 1LS
    front speakers need replaced
    i need to replace my front radio speakers. i have the monsoon system. what after market speakers will work ? there seems to be an issue with the ohms being different. i really dont want to replace the whole system. i like the sound. also need a magazine for the 12 disc changer. anyone know where i can get one ?
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    Georgia
    2014 Camaro 1LS
    I use Infinity Kappa 63.5i on the fronts....... You just gonna have to use 2 full range wires instead of all 4. Factory monsoon speakers uses 4 wires, 2 for mids, 2 for highs, that's why they are at 2 ohm's.... Just use the mids wires to connect the new speakers to, that's all. Don't fuck with the highs wires.....
    how do i tell the difference between the mid wires and the high ?
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    or just get the 62.7i's
    Georgia
    2014 Camaro 1LS
    dang wouldnt i be better off just getting the factory speakers ? i checked they are $ 60 each
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    or get the 62.7's
    Georgia
    2014 Camaro 1LS
    If you like the way they sound, go fo it.
    Just make sure you get the upgraded monsoon speakers, they handle more power.....
    Or you will still keep on blowing them.....
    http://cgi.ebay.com/ebaymotors/97-02...spagenameZWDVW
    can i get those from a dealer ? kind of leary about buying stuff off e-bay
    Georgia
    2014 Camaro 1LS
    how is the design better ? do u have to solder the wires on or do they have connectors ?
    Georgia
    2014 Camaro 1LS
    They are redesigned to handle more power, that's all... They have the same connectors as the ones you have, you don't have to do shit but plug them in. They are OEM....
    And don't even think about asking me what OEM means..
    whats OEM.......sorry thought this was a info web-site
    ruff ruff rotwiler's Avatar
    WA State
    LT's, 3400 stall, FIPK,CB
    2002 Z28
    The 62.7 is the easiest upgrade and sounds great. As with any speaker in any car, you will install them the same way. Cut the factory wires off the stock speakers and connect the new 62.7i's weather it be solder, a crimp on connector or electrical tape. Just make sure you connect the correct set of wires. Skip the supplied crossover with the 62.7is and should be a easy hookup. The door panel is the hardest part of it. I bought mine off ebay, local they cost around $160 and on ebay I had them in 3 days and was only $90. No speaker will have the exact same connectors as the stock ones, unless they are stock.
  1. Help: Replaced speakers & still get popping
    By Never-Enough in forum Stereo and Electronics
    Last Post: 07-22-2016, 03:19 PM
  2. Just replaced door speakers with Infinity 6032si - thumbs up
    By Thewilldog in forum Stereo and Electronics
    Last Post: 10-12-2010, 08:35 PM
  3. Who else has replaced their factory Monsoon speakers?
    By SiggyZ in forum Stereo and Electronics
    Last Post: 02-05-2008, 10:34 AM
  4. Replies: 4
    Last Post: 12-11-2007, 08:12 PM
  5. Replaced my busted front swaybar (pics)
    By Zapper2003 in forum Almost Anything Goes
    Last Post: 07-30-2007, 04:24 AM
