Results 1 to 20 of 40
    Retired Outlaw Sum Bitch
    Internet experts
    I do love the recommendations and some answers I see on the internet to simple questions.
    Put 20-50 oil in your LS1 to stop piston slap was a good one.....oil your KN filter with baby oil was a classic....but I just read one that stopped my heart....guy asked how to clean a MAF and I swear was told right off to clean his MAF with soapy water and blow dry it with a hair dryer.
    Dec 2004
    SS: NBM, tan top
    1998-SS, 2010 Jetta TDI
    you're supposed to rub motor oil all over it right?................
    i would do anything i was told b/c the internet is teh wise.
    Ahh crap... needmorepwr's Avatar
    SoCal
    '57,'63,'70,'91,'01
    The MAF sensor won't work right unless it calibrated to the muffler bearings.
    "now,you pissed us off!!" Trouble maker's Avatar
    Dyer, Indiana
    Quote Originally Posted by needmorepwr View Post
    which then the muffler bearings will go out because of the massive output of the calibrated exhaust tips...C'mon let's keep this going!......
    You must utilize a calibrated metric cresent wrench to adjust your muffler bearings....any deviations to these delicate settings will result in false readings to your soapy water cleaned MAF.
    Hello me meet the real me NOSSLP's Avatar
    Michigan
    I calibrated my exhaust tips by using a left handed hammer, and a dremel.
    The procedure is as follows:
    hang the tips with a coat hanger, tap them with the hammer, and listen to the tone. Then take the one with the deepest tone, and grind a little off the end and tap again. Repeat this as many times as necessary to get the desired tone on each tip, usually an a to an a sharp.
    Then if you go to the hardware store, and buy a bucket of steam, you can soak the tips to get any grinding dust off of them.
    Now my car sounds good, almost like it has a corvette motor in it
    Dec 2004
    SS: NBM, tan top
    now one thing also to rember is that the maf sensor is inversly proportional to the level and therefore density of the DOT-7 Blinker fluid, which inturn is directly proportional to the continual-transfunctioner core temperature
    When changing your summer air in your tires to the winter air never forget to recalibrate your exhaust tips.
    I'm out there so hide!!!! D!ck's Avatar
    TULSA, OK
    Black & Brilliant Silver
    1999&1997 SL600 6.0 V12's
    you guys are typin to fast. my pen aint workin. so change summer air to winter air,, but first change blinker fluid, then calibrate exhaust with left handed hammer, then rinse in a bucket of steam from ace?
    i heard thats worth 12ponies to the wheels!!!!
    Senior Member GOT1GOAT's Avatar
    Newcastle,De.
    04 GTO QuickSilver
    95 MarkVIII wifey white
    But did'nt you all know that if you scuff your tires with 20 grit sand paper you will get more traction ?
    04/A4 Quicksilver
    Magnflow catback-Resonator delete
    K&N drop in
    SAP front Grills and 05 hood
    Limo tinted windows-Gets me pulled over alot
    Diablosport Predator (RWTD) tune.
    Dec 2004
    SS: NBM, tan top
    na bra its 1200 grit
    Big$
    Guest
    Don't forget to change your johnson rod...u need a new johnson rod before every summer!
    Funny thing is...not a single person on that GTO specific sight has said shit.
    That poor bastard is out there rinsing his MAF with Dawn dishwashing detergent and blowing it dry with a hair dryer. Dumbshits............
    This is my signature. It is mine. Nobody else has one like it.
    alabama
    Gray
    2012 Challenger R/T
    Quote Originally Posted by Trouble maker View Post
    muffler bearings?? you mean the Chrome ones or nickle coated ???
    Dyer, Indiana
    ohh most certainly the chrome ones..the nickel coated bearings will trip the NC2 code which will directly offset the 3RC code..If this happens,it will be a long night!Please...anyone..correct me if I am wrong..
    alabama
    Gray
    2012 Challenger R/T
    problem with the Chrome ones is if you get them out of sequence it will get the water pump out of time ...And no body wants that !!!
    SoCal
    '57,'63,'70,'91,'01
    Maybe his piston return springs are shot?
    Pontiac Man Roscomp91's Avatar
    Aug 2006
    Indianapolis
    2000 TransAm WS6
    Nah you guys have it all wrong its the kanuter valve that is out of sync! because the turn signal fluid hasn't been changed properly puts the Maf outta tune!
    alabama
    Gray
    2012 Challenger R/T
    I know one time my horn needed some high test beep-beep grease ... Wow that was a close one .. Have you ever rebuilt the harmonic baffle equalizing impute meter ???
  1. any Experts ?
    By ahmadooo in forum GTO
    Last Post: 01-22-2011, 02:44 PM
  2. Help: Any audi experts?
    By Arrison24 in forum General Help
    Last Post: 09-04-2009, 02:15 PM
  3. Any bike experts?
    By silverWS6 in forum Almost Anything Goes
    Last Post: 08-28-2009, 09:48 AM
  4. C3 experts please help
    By justinmc978 in forum Corvette
    Last Post: 06-19-2009, 08:58 AM
  5. HELP!.. L92 experts look here
    By redsap05 in forum General Help
    Last Post: 02-16-2008, 05:17 PM
