Thread: Voltage Drop issue
10-06-2006, 09:17 AM #1
- Oct 2005
- El Paso, Texas
Met. Blue w/gold Flakes- 1998 Camaro Ultra-Z
Voltage Drop issue
Hello everyone, I just had a question that I am quite condused about. I have a red-top battery for my 1998 Camaro Z28, how I dont think it has any problems, it is new. When I drive, the voltage charge of my car is fine, pointing straight up on my guage. However, when I come to a stop and I hold the break during a red light for example, the charge declines greatly, under 10A or more. It also has a low charge after driving for a while. Nothing works, my power windows wont go up, I have to wait and press the gas to charge up a little just put up my windows. Does any one have any idea what is causing this/ or what I can do to fix it? Thanks, Richard
10-06-2006, 09:23 AM #2
- Jul 2005
- Jacksonville, FL
Bring it back to wherever you bought it and have them test it for you, just to eliminate it as being the cause. Could be the alternator...
10-06-2006, 10:17 AM #3
- Ft. Lauderdale, FL
Sebring Silver- 2000 CamaroSS
Sounds like a charging issue
10-07-2006, 10:12 PM #4
- Oct 2005
- Houston
Sebring Silver- 98 Z28
loosen the positive battery terminal , start car , let run, remove + terminal, if car dies it's alternator, which in turn hasen't charged your batt for crap, but it could be the batt they do go bad i've heard of redtops going bad in a year. i have one and i hope it lasts, i'm sick of all the f-body quirks damn i wish i could afford a vette
10-08-2006, 05:29 AM #5
10-08-2006, 03:05 PM #6
Pulleys.................
DID YOU BUT IT NEW?????? IF NOT A COMBO OF BAD CABLES/UNDER DRIVE PULLEYS WILL MAKE WEAK CHARGE AT IDLE!!!!
YOU NEED TO DO A "VOLTAGE DROP" ON THE + BATT. CABLE!!!Don't be afraid of the bottle!!! Be afraid of your tune!!!
pvc issue... vacuum leak....tune issue?
By okiels1 in forum General HelpReplies: 3Last Post: 03-05-2016, 09:10 AM -
Question: low voltage and sputtering issue related?
By JayTA98 in forum General HelpReplies: 4Last Post: 01-21-2013, 12:25 PM -
Having an issue with voltage (bump stop mod)
By 9t8z28 in forum External EngineReplies: 11Last Post: 10-30-2008, 09:03 AM -
Alt voltage drop w/asp pulley, A4 cars
By shortdog in forum External EngineReplies: 4Last Post: 03-17-2007, 12:03 PM
