Thread: Drag Radials
09-30-2006, 09:04 PM #1Member
- Jun 2006
- Bakersfield, California
red- 1959 corvette
Drag Radials
how much does a set of drag radials help your et in a manual car. Say some Nittos or Bfgs. In tenths please and 1/8 mile and 1/4 mile. I know this will be different based on specific mods, but im trying to get a rough estimate.
09-30-2006, 09:12 PM #2Member
- Sep 2006
- Central,Texas
Navy Blue Metallic- 2000 Camaro Z-28 SS
I would say anywhere from .3 to .5. Remember though, if you don't have the power to turn em they will actually slow you down trap speed wise.
09-30-2006, 09:16 PM #3Member
- Jun 2006
red- 1959 corvette
Just got her dynoed again, she turned 343 rwhp and 351 rwt, is that enough? Picked up 8 rwhp with the dual cutouts open.
My mods on the 99 FORMULA
Whisper lid, K&N, B&M Short Throw, CAI, Magna Flow Exhaust, UMI torque arm, FT LT hdrs, ORY, dual cutouts, 4.11 Gears, BMR SFC, BMR MSB, BMR lower control arms, Poly motor and tranny mounts, 575/568 232/227 111 lobe cam, Taylor wires, ngk tr55s,1 10in. JL W3 for beat.
10-01-2006, 06:55 AM #4
can't really say. they only help if you have traction issues to begin with. then you have to remember they are causing more friction. so, you have to overcome that amount of drag.
read this:
http://69.42.146.24/forums/showthread.php?t=30107Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
10-01-2006, 06:56 AM #5Junior Member
- Jul 2006
- Lafayette/Indy, IN
Rally Red- 2000 Camaro Z28
gearing helps too. I had 373HP with 4.33 gears and I was spinning the crap out of my nittos, they are 315/35R17. They are good for the street but bad at the track. If you can feather the clutch then you can cut some good times. I prefer ET streets at the track because I can dump the clutch at 5k and let her rip.
10-01-2006, 09:55 AM #6Member
- Los Angeles
Black- 2001 Trans Am WS6
They can help out alot, though I advise against the nittos. Nittos need to be heated up for a ridiculous amount of time. It's great if you have line lock, but otherwise you'll have to do a brake stand. The BFG's hook alot better, and they don't require all that much of a burnout.
My guess is you'll drop .2 - .3 sec. from your 60' time.2001 T/A WS6 M6
LS6 Cam/Springs, Lid, SLP Pulley, Magnaflow Catback, TBCB, Richmond 4.10 gearing, Panhard Rod, Strut Tower Brace, Low Control Arms, Lou Thesz Short Stick
Dyno 351rwhp/341rwtq, and tuned by RacePrep via HP Tuners.
need drag radials
By tomsws6 in forum Wheels and TiresReplies: 0Last Post: 06-29-2008, 04:58 AM -
New M/T drag radials
By Firebirdjones in forum Parts For Sale / TradeReplies: 0Last Post: 04-12-2007, 10:39 AM -
Better Drag Radials
By GUSHER in forum Wheels and TiresReplies: 11Last Post: 11-18-2006, 09:34 AM -
BFG Drag Radials
By trippleh in forum Parts For Sale / TradeReplies: 14Last Post: 11-10-2006, 01:26 PM -
WTB: 16'' M/T drag radials!
By Musclefan21 in forum Parts Wanted / TradeReplies: 0Last Post: 10-19-2006, 09:39 AM
