Results 1 to 13 of 13
Thread: d/r too tall?
    Aug 2006
    michigan
    2001 camaro
    d/r too tall?
    i bought some mickey thompson et srtreet radials and they are 1/2 an inch taller than stock. my car is not modded yet. my 60 ft time stayed exactly the same (1.98) and my trap speed dropped 1 mph. i hook right up but they slow me down one tenth. why is that? should i find a smaller tire or can i grow into these ones?
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    bud your in the wrong section...try posting in the wheels and tires section..or the drag racing section
    mods- suncoast creations hood with functional lt1 style airbox, ls6 intake, QTP longtube headers, QTP ORY, UMI SFC, Adj. LCA with relo brackets, UMI adj. panhard bar, Koni SA and strano springs,Torq Thrust M 17s 9.5 and 10.5 with nitto 555Rs, tuned by Frost
    Quote Originally Posted by Modulistic View Post
    sometimes you get owned, sometimes you own.
    Aug 2006
    michigan
    2001 camaro
    Talking
    damn my bad, i was originally gonna ask about getting new gears to see if that would help, but i started rambling instead.
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    1/2" taller isn't going to be the reason you slowed down. the reason why is it takes more power to turn those tires down the track because of the increased friction. also, the initial launch is requiring more torque as well. people have the misonception that just because they put a sticky tire on, it'll automatically drop their ETs. this is only true if you are having launching issues.
    Shepherd, Michigan
    98' trans am
    Quote Originally Posted by juSStin View Post
    well gears always help...if you have a m6 get your ass some 4.10s if you have a a4..get a 3000+ stall converter and tranny cooler...then get some 3.73..those will help you soooooooo much
    Aug 2006
    michigan
    2001 camaro
    with out the dr's i cant launch at more than 1100 and then i really have to feather the gas. i still break lose half the time. so i figured i those tires would help. but the whole friction thing makes sense now.
    Shepherd, Michigan
    98' trans am
    well you break loose with d/r at 1100? or with street tires? i think mrr is telling you need to get your rpms up higher at start so the ls1's torque can help it..get it higher into the curve..but i'm telling you a stall will help you alot with your launches ...if you have a a4 that is
    Aug 2006
    michigan
    2001 camaro
    yes i have the a4, and its my street tires break loose at 1100. the m/t's are just too sticky for me right now i guess. i was lookin at converters, but im on a tight budget. i found the tci street fighter for $470. what kind of gain should i expect with that.
    Aug 2006
    michigan
    2001 camaro
    with m/t's i can launch it as hard as my stock converter will let me and mach the gas and i will have no traction issues, just slower times.
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    You need a converter.
    Forged 383 | ATI D-1SC
    NX MAF Kit | 222/226 .585 115
    AS Stage II 6.0L FI Heads
    Aug 2006
    michigan
    2001 camaro
    3000 or so ? what kind of gains?
    Aug 1999
    No Where
    At least a 3000. About a half a second.
    Aug 2006
    michigan
    2001 camaro
    sweet thanks
  1. Tall Drivers help
    By 980birds in forum Corvette
    Last Post: 11-08-2008, 04:40 AM
  2. how tall are you?
    By 310stanger in forum Almost Anything Goes
    Last Post: 09-14-2007, 01:16 PM
  3. Any tall people here?
    By kråžê™ in forum Firebird / WS6
    Last Post: 03-29-2007, 04:26 AM
  4. Replies: 2
    Last Post: 01-29-2007, 08:26 AM
  5. Someone tell me how tall these tires are.
    By x-40oz-x in forum Wheels and Tires
    Last Post: 08-16-2006, 07:50 PM
