Results 1 to 10 of 10
09-26-2006, 10:26 AM #1Senior Member
- Jul 2006
- indiana
black, 05 Roush- black, 99 T/A WS.6
Ported Throttle body and cable Question
I should of done more research before I purchased a ported throttle body but anyway I have a 99 WS6 and purchased a ported TB off a 01 and now have the problem of my throttle cable being too short, the sprocket that the cable attaches too is larger on the 01 throttle body and my cable holds it open enough to cause high reving. Is it possible to adjust my cable and make it a little longer or do I need to just re-sell and buy a tb off 99 specifically? Thanks for your help fellas.
Wheeler99WS6
09-27-2006, 11:54 AM #2Senior Member
- Jul 2006
- indiana
Help me out guys, some one has to know.
09-27-2006, 05:50 PM #3JOSEY FUCKING WALES!
- Nov 2005
- College Station TX
Black- 2000 &2002 Z28
I got the same problem in Reverse lol.....Small Throttle linkage, too long of cable lol
09-27-2006, 06:07 PM #4Likes twisty roads
- May 2006
- England but from TX
Light Pewter Metallic- 2K Camaro Z28
Swap your old ones to the newer ones. Problem solve.
09-27-2006, 08:03 PM #5
You can adjust the cable but if there's enough slack I dunno
....but it's worth a shot.
09-28-2006, 06:54 PM #6JOSEY FUCKING WALES!
- Nov 2005
where can u buy a new linkage?
10-01-2006, 01:32 PM #7Senior Member
- Jul 2006
- indiana
I did in fact end up swapping cam and shaft from my stocker to the ported one, worked out just fine, was easier to do than I thought it would be. Thanks guys.
Wheeler99ws6
10-01-2006, 04:40 PM #8JOSEY FUCKING WALES!
- Nov 2005
howd u do that?
10-02-2006, 08:52 AM #9txcosmosGuest
There should be a cable adjuster, along the cable, somewhere above the intake manifold. Just follow the cable back, and there should be a tube with a clip on it. Undo the clip and slide the cable back and forth, until you have just enough slack, then slip it back on and roll....
10-02-2006, 02:46 PM #10Senior Member
- Jul 2006
- indiana
uscrew the butterfly blade, slide it out. Get a rubber or brass mallet and hit the end of the shaft that held the blade, not the end the cable hooks too but the opposite end, use rubber or brass because it is softer than what you are hitting and wont cause the shaft to mushroom....couple good taps and it will come right out, it has a small thin lock nut but it will come off with a couple taps, no need to reuse that nut I talked to a guy that does alot of porting of tbs on LS1tech.com that is how I obtained my knowledge. Give it a shot.
90 92 mm Throttle Body TB cable driven
By MnLS1 in forum Parts For Sale / TradeReplies: 6Last Post: 02-11-2010, 04:43 PM -
Question: Cable operated throttle body
By 09 Truggy in forum Computer & TuningReplies: 1Last Post: 06-24-2009, 03:14 PM -
throttle body cable??
By 1TA LS1 in forum General HelpReplies: 7Last Post: 08-07-2007, 08:45 AM -
Dual Cable Throttle Body
By 9t8z28 in forum External EngineReplies: 7Last Post: 12-13-2006, 06:46 PM -
SLP LS6 intake, Whisper Lid, Ported Throttle body, Ported MAF
By cru ss n in forum Parts For Sale / TradeReplies: 15Last Post: 05-24-2006, 08:22 AM
