Thread: Bad Flywheel?
09-16-2005, 08:52 PM #1
- RIGHT BESIDE THE LEMON TREE IN HELL!!!
LIGHT PEWTER METALIC- 1999 SS CAMARO
Bad Flywheel?
Alright I posted on here before having alot of trouble with my Spec Stage III and SLP billet steel flywheel. well I found that the problem was the bolts had almost worked their way out I assume it was either from the chatter or the vibration that is supposedly normal so I took them out and the flywheel holes are and were to begin with kinda loose fitting? So we loctited the hell out of them and torqued them. Alright now after I went to the track and ran maybe 10 times I'm getting a vibration and I'ts only at certain Rpms and certain gears it seems like it dont happen all the time? what do I do? Oh and by the way you can launch a stock rearend atleast 6-8 times on drag slicks @4000 RPMS maybe that is why I've got a vibration but still what is it?
09-16-2005, 09:06 PM #2
i have been hearing a LOT of bad things about Spec Clutches, it seems like everyone spends all this money on them and has so many probles?
im glad i have an auto.
09-16-2005, 09:16 PM #3
I dont know if its the clutch or the flywheel, or something else? nobody knows jack S--t around here so if I want it fixed I guess I'll have to go on a road trip? if it makes it? lol
09-21-2005, 06:04 AM #4rays00ramairGuest
i gotta hays flywheel and centerforce clutch d/f.no chatter ever but i used all new bolts on install and blue loctite.do not reuse the pp bolts i no they are torque to yeild and a one use item.
Help: LS1 flywheel
By camarorus in forum General HelpReplies: 3Last Post: 01-30-2011, 03:43 PM -
Wanted: OK, what flywheel do you have?
By 01blackbird in forum Parts Wanted / TradeReplies: 0Last Post: 04-07-2010, 07:35 PM -
Flywheel...
By LT4Hawk9 in forum Manual TransmissionReplies: 1Last Post: 03-07-2009, 03:16 PM -
flywheel?
By chevyboy82188 in forum General HelpReplies: 0Last Post: 02-18-2009, 06:47 PM -
LS2 flywheel
By SS#1531 in forum Parts For Sale / TradeReplies: 1Last Post: 09-16-2007, 07:51 AM
