Thread: Stock valves?
09-25-2006, 04:45 AM #1Junior Member
- May 2006
- Minnesota
Red- 1987 Trans Am
Stock valves?
I have a Ls1 with 64,xxx miles. I have a valvetrain upgrade, LS6 intake and so on. My question is, are the stock valves good for the job? I can slide them in and out, is that normal with no springs installed?
09-25-2006, 02:44 PM #2Member
- South of Heaven
Navy Blue Metallic (NBM)- 2002 Camaro SS
Yeah that is how they are supposed to work. Although if you have been playing with them I would install new valve seals as cheap insurance. The valve spring locks hold the valves to the retainer and the spring pressure holds them against the valve seats...
EDIT: Are you changing the springs with the heads still on (easiest way to do it)? If so you need to use either the TDC method of keeping the valves up or a compressor with attachment to pressurize the chamber.
09-27-2006, 06:49 AM #3Junior Member
- May 2006
- Minnesota
Red- 1987 Trans Am
the motor is out of the car and the heads are off.
09-27-2006, 06:49 PM #4Member
- South of Heaven
09-28-2006, 09:58 AM #5Junior Member
- May 2006
- Minnesota
Red- 1987 Trans Am
Thanks!
Cam update and tip.. Lingenfelter GT1 stock heads and valves
By DW2000TA in forum Internal EngineReplies: 3Last Post: 02-21-2012, 09:19 PM -
Stock LS6 exhaust valves wanted
By onetonzr2 in forum Parts Wanted / TradeReplies: 0Last Post: 10-25-2010, 11:09 AM -
Question: Valves
By blackout5.3 in forum Internal EngineReplies: 0Last Post: 07-31-2009, 02:49 PM -
Valves
By Phlash_riot in forum External EngineReplies: 2Last Post: 11-01-2006, 10:29 AM -
WTB - stock LS1 valves, retainers & keepers and/or 918 springs
By white2001s10 in forum Parts Wanted / TradeReplies: 1Last Post: 09-06-2005, 11:17 PM
