Results 1 to 20 of 96
Thread: How fast will my 2001 SS go ?
09-21-2006, 11:38 PM #1
I am dying to find out what my car will do top end. From my online research I have found out it is governed @ 160 m.p.h. Is that true ? If so how can I ungovern it ? I am to chicken to open it up all the way. I have went 110 m.p.h. a few times but always let off. lol . Whats the fastest all u other guys have went ?
09-22-2006, 12:05 AM #2Junior Member
- Sep 2006
- ontario
HUGGER ORANGE- 1999 camaro SS
SS's shouldnt have a governor on them. i have personally hit 250k/160mph on the odometer in mine, before some moron pulled out in front of me on the highway. it was still picking up speed. in sixth the rpms were just about at 2000.
really, how can you miss a big bright orange coming at you doing over twice the speed you are?!!!?
09-22-2006, 12:49 AM #3
09-22-2006, 08:51 AM #4Junior Member
- Apr 2006
- Moon, PA
White- stolen by "Josh Steel"
If you look over the passenger side wheel well under the hood there should be a lone red wire with a quick disconect. it is used for tuning the car's timeing. if you disconnect it you can cram any timeing down the computers throat untill you plug it back in. this will disable any speed block if you have it. got mine to burry the needel when I was out in Montana. I had also already used the hypertech power programer. I don't know if it acutly has a speed block or not so I just but it up the the max 225mph (I think). Any way, unless you have a lot of straight road with plenty of visibility the speed block shoud never pose a problem for you if it has on at all. The red wire trick works on almost all OBDII GM products as well. usualyl in the same location. Be forwarned, the wire will also disable tachomiter and rev limiter, you will have to shift on the pipe alone.
09-22-2006, 10:58 AM #5
09-22-2006, 11:05 AM #6Member
- Aug 2006
- Madrid, Iowa
red- 02 trans am ws6
156 with rpm's round 4000 to 4500 in 6th gear, to busy taking a picture of the speedo with my phone to notice rpm's
09-22-2006, 11:08 AM #7
09-22-2006, 11:38 AM #8King 0f n00bz
- Jan 2006
- Shepherd, Michigan
no all camaros and firebirds have governors on them..it has to do with the speed rating of the tires...depending on what tires you have on now..the speedo will be off...since at those speeds tires deform slightly..so yea the speedo said 160..but you probbally only going 155ish..so thats why you were still pulling
09-22-2006, 11:47 AM #9
ive only had mine up to about 120
old man has had it up to 135....
09-22-2006, 11:50 AM #10King 0f n00bz
- Jan 2006
09-22-2006, 11:56 AM #11Senior Member
- Sep 2006
- Canby, Oregon
Pewter- 1999 Camaro SS-M6 #1775
Ive hit 155mph in 5th gear and had to slow down for a corner! what a RUSH!!
12.6 at 112
09-22-2006, 12:27 PM #12
if that dont kill your pads/rotors
09-22-2006, 12:37 PM #13Junior Member
- Aug 2006
- port st lucie fl. 34986
navy blue metallic- 2000 camaro ss
I had my ss up to 135,then i thought of the guy who built the tires.My life is now dependant on him.I let off.
09-22-2006, 01:02 PM #14Awaiting Activation
- Mar 2006
- LS1 land
I've been to 135 and it i wanted more, but you need a lot of road.
09-22-2006, 04:51 PM #15
09-22-2006, 06:35 PM #16Junior Member
- Jul 2006
- Comstock WI.
White- 1999 Camaro LS1
i was raceing an srt-4 on a count road, he claimed his car could do 150+, and he wanted to race and top our cars out. i was ahead of him the whole way, and i ony had mine up to 143 befor i let off, i have an a4 with 2.73 gears, and i was at 5800 rpms in third, the 4th gear shifted and thats when i let off. i just have a z28 tho, not an ss
09-23-2006, 11:35 AM #17CRL 01 SSGuest
HPTuners says that the governor is set at 162 mph from the factory for 2001 LS1 Camaros. I only hit the governor once racing a 2002 Z06 on the interstate. It sucked because it just cut the engine off. I've since had the governor bumped up. I don't think that you can completely erase the governor with HPTuners, but you can bump it up to like 256 mph so that there is no way you could hit it.
09-23-2006, 11:39 AM #18Senior Member
- Jul 2005
- Earth
414 RWHP 395 RWTQ- 00 Black Ram Air Trans Am
I hit 147 with just a cutout and a lid coming home from Syracuse before on open roads. With all my mod slisted below I've only had enough road to get up to 143 before having to brake.
'00 Black Ram Air TA TR224/224 PRC 5.3 59cc Heads
Pacesetter LT ORY Hooker CB 414 RWHP 395 RWTQ
BMR PHR, SFC,LCA & TM. Bilstein HD shocks 1LE FSB
Firehawk Rims w/KDW Custom Headrests & Floormats
09-23-2006, 11:53 AM #19
I've had my 98 T/A up to 150mph, but had to slow down because I was approaching a curve. My older brother has had his SS to 155mph+ and he says it was still picking up speed before he let off.
09-23-2006, 12:15 PM #20
Ls1 Go Fast Parts*.Needs to go Fast!!
By king_speed in forum Parts For Sale / TradeReplies: 8Last Post: 08-08-2007, 12:41 PM -
check out this fast ass supra!!! then a crazy fast honda...
By got-a-ls1 in forum Almost Anything GoesReplies: 5Last Post: 08-27-2006, 03:51 PM -
WTB: 2001 or newer FAST FBODY
By D-V-OuSS in forum Vehicles For Sale / TradeReplies: 9Last Post: 04-27-2006, 07:35 PM -
FS: 2001 LS1 WS6 PRICE REDUCED to sell fast
By NhraWiz in forum Vehicles For Sale / TradeReplies: 5Last Post: 09-29-2005, 09:46 PM
j/k...in all reality..most people will hit the limiter..maybe between 1-5 times..shits scary when your going 160
