Results 1 to 11 of 11
Thread: what will break????????
09-21-2006, 08:40 PM #1Junior Member
- Mar 2006
- GREENVILLE, NC
WHITE- 2001 TRANS-AM
i have a 01 ws6 with a 12bold 3:73, steel drive shaft and stock t56 just got some et streets i do have some motor mods dyno a little over 400.
what is the weak spot now
09-21-2006, 09:42 PM #2Member
- Jun 2006
- Bakersfield, California
red- 1959 corvette
Clutch
09-21-2006, 10:21 PM #3
transmission is the next to go. I rebuilt mine with viper internals at 425 rwhp.
09-22-2006, 11:51 PM #4
09-23-2006, 12:05 AM #5
still, the stock internals on a nicely modded car does have more to be desired of. Clutch, yes it's good to about 400 then you'll get some slipping
09-23-2006, 12:06 AM #6Detailing + Design
- Pittsburgh, PA
i have more posts then you, i'm right, OK!?
09-24-2006, 01:59 PM #7
09-24-2006, 10:17 PM #8
the only thing that the '01-02 trans have are the upgraded shift forks and rails...external differences include slave cylinder... other than that internally they are identical. best thing you could do for that transmission is to get the torque arm off of it...stock GM around 400 horse is normal for a T56 relocate the torque arm you can easily see 500 ive seen 600...you would def have to have a bad ass clutch for that though...the torque arm puts way to much stress on the case and it actually starts shifting around the internal alignment of the transmission itself...other than that id say driveshaft...
09-25-2006, 06:52 AM #9Detailing + Design
- Pittsburgh, PA
01/02's have brass synchronizers, the previous years have carbon.
09-25-2006, 01:28 PM #10
not to get off the subject, but who makes a good torque arm relocation mount?
09-26-2006, 08:24 PM #11Junior Member
- Mar 2006
- GREENVILLE, NC
i just put in a spec 2 clutch
Engine Break-In Guide - Break-In Without Breakin'
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 03-17-2011, 09:40 AM -
break in
By Ramairgod84 in forum Almost Anything GoesReplies: 11Last Post: 08-22-2010, 11:24 AM -
check out this break dancer break
By pecha in forum Almost Anything GoesReplies: 4Last Post: 02-23-2009, 09:20 PM -
Break through at the gym
By Blitzed in forum Almost Anything GoesReplies: 83Last Post: 06-14-2008, 04:02 PM -
What does SVT break down to be?
By SAGGIN in forum Almost Anything GoesReplies: 16Last Post: 03-19-2008, 05:54 PM
