Thread: Hyper Flex Bushings
09-21-2006, 02:15 PM #1Junior Member
- Apr 2006
- Moon, PA
White- stolen by "Josh Steel"
Hyper Flex Bushings
I just put on a set of hyper flex bushings (BIG DIFFERENCE). I did the entier car and everything fit well untill I got to the front LCA's. I don't know if hyperflex sent me the wrong parts or if they got cheep at the shop when they replaced the LCA's the dimensions were all wrong I had to carve down the LCA's to fit and remove a lot of material form the bushings as well. Has anyone else put the compleet kit on there car? did they have similar issues?
09-22-2006, 02:20 PM #2Junior Member
- Apr 2006
- Moon, PA
Any Anwsers? I am bout to just replace the 7 day old front LCA's out of fear. I don't know if somthing might let loose now or not. Anybody Anybody Fairis Fairis Buler!
09-22-2006, 02:58 PM #3
did you call them? after all, they would know.
09-25-2006, 08:41 AM #4Junior Member
- Apr 2006
- Moon, PA
I called them but they were actualy dicks! They even went as far as to ask if I know what I was doing! But anyway they send me an instilation diagram that was the best I could get out of them. The part #'s mach up with what they gave me. They just don't fit. Also the directions say to remove the shock collers. That would be a major under taking. They are welded in. I finaly got it all forted out I had to hacksaw/dremmel the shock collers down to about 1/2 there size then I used a router and a home made jig to remove material form the bushings to reduce the O/D. Finaly got everything in and it works realy well. I am very happy with it. I just question if this is going to cause issues down the rode. this is the only hafassed thig on my car.
2009 Ford Flex - Hot Rod Ford Flex
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 08-10-2009, 10:00 PM -
Question: Hyper chip ?????`s
By beunme in forum General HelpReplies: 5Last Post: 01-28-2009, 07:07 AM -
FS: Hyper-tech programer
By PureSShp00 in forum Parts For Sale / TradeReplies: 14Last Post: 09-29-2008, 12:46 PM -
hyper pac
By blackTA6585 in forum General HelpReplies: 0Last Post: 01-22-2007, 02:46 PM -
What is hyper silver?
By Cerwin Vega Fan in forum Wheels and TiresReplies: 0Last Post: 12-21-2005, 09:35 PM
