Results 1 to 3 of 3
    Junior Member AirMarcus's Avatar
    Bossier City, la
    RED
    01 Z28
    Hole drilled in my throttle blade?
    Is there supposed to be a hole in my 01 z28 throttle blade? I have heard of people drilling one to help idle characteristics with a big cam, which this one has. I have problems at idle, surging, and sometimes dies after coming off the gas. Can this be remedied with the throttle stop screw? The car was dyno tuned by LG motorsports in Dallas (180 miles from me) so I would like to fix it myself if i can. the cam specs are 228/232-588/574@114 backed up by ported &poplished heads that flow to 304 with diamond forged pistons. btw the maf appears to be aftermarket & altered.
    Member SSpdDmon's Avatar
    Farmington, MI
    SOM
    '01 Camaro SS
    Usually, you'll need a tuning package like EFI Live or HPTuners to truly fix idle & part throttle issues on a heads/cam car. Most shops don't get idle right. They mainly focus on the dyno numbers and getting the car to stay running. Idle and drive-ability don't always make it on the list of things to do when they've got a line of cars to tune.
    Find someone with a scanner to see where your IAC steps are. When the car has been up to temp for a few minutes, the IAC should be in the 60~70 range. If it's not, then yes...you need to adjust your throttle body set screw or possibly drill the hole out some more to bring them in line. If it is, there are a few tables that need to be dialed in within your tune.
    Bossier City, la
    RED
    01 Z28
    thanks, i have an actron scanner with live monitoring but i do not know if it will mon. that set of responses. I only checked for codes( none).
  1. Blade Runner 2
    By SiggyZ in forum Almost Anything Goes
    Last Post: 08-28-2014, 09:42 AM
  2. Would a small hole in the TB blade cause all of these problems?
    By Hurley711 in forum Computer & Tuning
    Last Post: 08-27-2007, 08:33 PM
  3. WTB throttle body blade
    By mvvette97 in forum Parts Wanted / Trade
    Last Post: 02-26-2007, 07:22 PM
