Results 1 to 20 of 34
Thread: Which torque arms better?
09-19-2006, 02:50 PM #1Member
- Jun 2006
- Bakersfield, California
red- 1959 corvette
Im going to purcase a torque arm and was wondering if spohns or bmr is better. Also will this take any time of my et, and how much will it roughly take off.
My mods on the 99 FORMULA
Whisper lid, K&N, B&M Short Throw, CAI, Magna Flow Exhaust, UMI torque arm, FT LT hdrs, ORY, dual cutouts, 4.11 Gears, BMR SFC, BMR MSB, BMR lower control arms, Poly motor and tranny mounts, 575/568 232/227 111 lobe cam, Taylor wires, ngk tr55s,1 10in. JL W3 for beat.
09-19-2006, 03:17 PM #2Member
- Jun 2006
red- 1959 corvette
Im getting a torque arm and was wondering if I should go with spohn or BMR, the spohns 100% bolt on, also how much will this help my ets.
09-19-2006, 03:21 PM #3Slow'er'Ass
- Thornton, CO
Umi
09-19-2006, 03:48 PM #4
I second the vote for UMI.
They have quality products that imo cannot be beat.
09-19-2006, 05:02 PM #5
both arms are basically the same. the neat thing with the spohn is the driveshaft loop that comes with it if you order it that way. hard to say how much lower your ET will. if anything, it'll make you 60ft more consistent.
09-24-2006, 10:36 AM #6Junior Member
- Dec 2005
- Ms
Another vote for UMI!
09-24-2006, 07:23 PM #7Senior Member
- Aug 2003
- Honolulu HI
Pewter- all bore 370 Trans Am
umi for the price. i have the spohn chassis mounted. its pretty noisey and clunks on occasion, but i do have pretty good traction.
09-25-2006, 07:02 PM #8Member
- Jun 2006
red- 1959 corvette
Does yours have the poly bushings or chromoly ends? Also did you get the drive shaft loop, and why does it clunk. Do you think your more likely to bust the rear with it? Sorry for all the questions
09-25-2006, 07:09 PM #9Senior Member
- Aug 2003
- Honolulu HI
poly bushing, yes i had a loop, but i had to cut it off (long story) it clunks cause thats the nature of it. its just how they are. i dont think you'll break the rear. id think if anything, id would be the torque arm bracket that bolts to the pumpkin. whichever you get, be sure to get the longer bolts.
09-25-2006, 07:12 PM #10Member
- Jun 2006
red- 1959 corvette
Does it come with longer bolts or are you supposed to use the stockers? How much longer bolts do I need if it doesnt come with them?
09-25-2006, 07:30 PM #11Senior Member
- Aug 2003
- Honolulu HI
it doesnt come with it, but you can order them along with the new torque arm. they cost extra, but they're needed because the stockers dont reach through all the way.
09-25-2006, 07:42 PM #12Member
- Jun 2006
red- 1959 corvette
Thanks bro, also did it help your et out and 60 ft out at all. Another thing off topic, im installing cutouts and wanted to know if its better to have two(after each header) or just one after the y merges?
09-25-2006, 08:03 PM #13Senior Member
- Aug 2003
- Honolulu HI
to be honest, i havent got to take it to the track yet. ive got a few more things to fix then i should be there, but traction has increase like a mofo!! thats a tough one. i think its preference more than anything. if you dont have cats, then right after the merge...somewhere in the I pipe. if you have cats, then you could opt for the dual cutout before the cats.
09-25-2006, 08:10 PM #14Blown, Stroked, & Sprayed
- Aug 1999
- No Where
I run the BMR with the relocation kit. No issues at all.
Forged 383 | ATI D-1SC
NX MAF Kit | 222/226 .585 115
AS Stage II 6.0L FI Heads
10-03-2006, 06:19 AM #15Evr sena bdgr killa snak?
- Dec 2005
- Research Triangle Park, NC
Pewter- '99 Z28 M6
I have the BMR trak pak, with the torque arm mounted to a bar across the subframe connectors. I had the stock LCA's, and I took her to the drag the other Sunday and the BMR torque arm BROKE then BENT. I should post a pic of it. Albeit, I have beaten that car like a borrowed mule in the one year I have had it.
Actually, I am impressed the 10-bolt has held up. I got in touch with BMR, and we came to the conclusion that the stock LCA's contributed to most of the force being put on the torque arm. So, I ordered a new BMR torque arm, with the RELOCATED LCA brackets and new BMR LCA's. I shouldn't have any more traction issues, and it should be solid as a rock. I will do the install myself to make sure it is done right.
By the way, ALL BMR stuff comes in the Silver Vein color now. Looks kinda like Pewter.Heads 'n Cammed, Moser 12, 3.73's, Weight Reduction, 13" Brembo Kit
BMR track suspension, full exhaust, the works...
412whp/394wtq 1/4 mile slip coming soon!
Gone: '01 Laser Red Cobra 3.73's/Full Bolt-ons
10-03-2006, 08:14 AM #16Senior Member
- Aug 2003
- Honolulu HI
i ordered the umi adj. tranny mounted TA and relocation kit last night. ill post up how i like it compared to my spohn chassis mounted TA. (btw, my spohn is for sale
10-03-2006, 08:15 AM #17Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Is the UMI cheaper than the BMR?
10-03-2006, 08:20 AM #18Senior Member
- Aug 2003
- Honolulu HI
for the torque arm and the relocation kit it came out to 515 shipped. im pretty sure thats cheaper than the BMR.
10-03-2006, 08:31 AM #19Evr sena bdgr killa snak?
- Dec 2005
Pewter- '99 Z28 M6
Paid 430 shipped with new torque arm, relocation brackets, LCA's. I didn't have to buy the whole torque arm kit though, just the arm itself (or A-frame), without the eyenut thingys, it comes with a new poly bushing though!
10-03-2006, 08:49 AM #20Senior Member
- Aug 2003
- Honolulu HI
not a bad price! what brand?
Discussion on Torque Arms
By TA98 in forum General HelpReplies: 5Last Post: 04-12-2012, 09:33 AM -
Torque arms
By RichWS6 in forum Firebird / WS6Replies: 6Last Post: 06-29-2011, 01:18 PM -
torque arms?
By bpopham22 in forum Firebird / WS6Replies: 3Last Post: 03-11-2010, 06:42 PM -
Torque arms what to choose?
By BANDITO in forum Suspension and HandlingReplies: 67Last Post: 02-03-2010, 07:17 AM -
torque arms
By dklowrider in forum Suspension and HandlingReplies: 7Last Post: 07-22-2009, 07:08 PM
