Thread: Question On Egr Valve!?!
09-19-2006, 08:50 AM #1TWISSTED
- Mar 2006
- SARATOGA,N.Y.
RED- 00' Camaro SS/6spd
Is there a way to delete EGR system from 00' Z-28 LS1 intake setup!
I was told they make a block off plate to cover hole on intake,and that you can program it out in order to avoid check engine light and pass inspection.
Is this true?
If so,where can you find parts to do this?
09-19-2006, 10:07 AM #2
09-19-2006, 01:09 PM #3TWISSTED
- Mar 2006
- SARATOGA,N.Y.
Thanks for the input
So if I buy a handheld tuner will that do the trick,cause I was planning on buying one this winter anyhow?
09-19-2006, 09:51 PM #4
An expandable freeze out plug works fine for the intake. You can buy block offs for the manifolds but it's not hard to just make them. Trace around your stock egr plate that bolts to the manifold and cut it out then put it back on with a gasket and you're done. I'll have to look in the shop at my old stock manifold for the freeze out plug size. 1 3/8" keeps coming to mind but I'll check to make sure.
09-20-2006, 08:19 AM #5TWISSTED
- Mar 2006
- SARATOGA,N.Y.
thanks!
09-20-2006, 08:50 AM #6Senior Member
- Jul 2005
- Jacksonville, FL
It is 1 3/8", buddy of mine got his from Auto Zone - think they called it an expansion plug? - it's gold and has a nut on top to tighten it.
09-21-2006, 06:42 PM #7
Help: Valve cover question
By 98TransAmWs-6 in forum General HelpReplies: 22Last Post: 02-01-2013, 05:49 PM -
PCV valve question
By SS Camaro UK in forum General HelpReplies: 19Last Post: 05-04-2012, 08:44 AM -
PCV Valve Question
By thearborbarber in forum General HelpReplies: 38Last Post: 03-06-2008, 04:18 PM -
egr valve and header question
By 35thAnniZ28 in forum External EngineReplies: 3Last Post: 05-11-2007, 07:33 AM -
valve question
By shady milkman in forum Internal EngineReplies: 8Last Post: 09-27-2006, 04:41 PM
