Results 1 to 11 of 11
Thread: tire size question
09-18-2006, 08:52 AM #1Member
- Jul 2006
- jacksonville nc
red- 1995/2002 camaro z28's
tire size question
right now i have 275/40/18 on my rear on a 18/9.5 rim, would a 295/45/18 tire fit on that rim, and would it rub anything?
09-18-2006, 09:28 AM #2SUPREME member-oderator
- Nov 2005
- Lost in Texas
Custom Slate Blue- 99 B4C
when you go wider you need to go shorter (the middle number needs to get smaller) You would have a 4x4 look if you did that. The 295 will fit, but might hang over the sides of the rim a bit. You need to step it down to a 295/35 at least to keep from getting WAY too much sidewall on there and making your speedo farther off
09-18-2006, 09:46 AM #3M6 King
- Mar 2006
- WI
- Blog Entries
- 1
The tread on the contact patch is going to start getting rounded also. I have 285/35/18 on the rear on a 9.5 and it looks like if I'd go any wider I would start losing contact patch area. I'm thinking of getting a pair of 10.5's for the rear the next time I get new rear tires for I can go wider.
09-18-2006, 10:38 AM #4Member
- Jul 2006
- jacksonville nc
i just know i had 275/ 35s and i thought the sidewall was way to thin and didnt fill up the wheel well enough, but maybe in a 295 it would be better
09-19-2006, 04:56 AM #5Member
- Jul 2006
- jacksonville nc
does anyone run a 295/40 on here? if so could you post a pic please
09-19-2006, 06:28 AM #6
Right now i have 245/40/18s on some amercian racing rebels that are 18x10. I am thinking about getting some 275/35/18 for the rear. would these fit properly because the dealer cant promise they will and i will be stuck with them
09-19-2006, 03:57 PM #7
use 295/35-18.
09-20-2006, 03:29 AM #8Member
- Jul 2006
- jacksonville nc
can someone post a pic of a 295/35/18, i just want to see how tall the sidewall is before i buy them, i hate my 275/35/18s, the walls so short it ruins the look, but on a 295 it should be a little taller, a picture would help alot, thanks for everyones help so far
09-20-2006, 08:33 AM #9Crazy Canuck !
- Jun 2002
- Montreal, CANADA
the tire would be 2.5" taller than stock size.... go with a 35 series... better matching sizes
Eugenio_SS
09-21-2006, 04:01 AM #10Member
- Jul 2006
- jacksonville nc
yea i just hate a really thin sidewall, but thats what im going with, ive been looking around for a decent set for a fair price, any recomendations where i should look?
09-21-2006, 07:46 PM #11Crazy Canuck !
- Jun 2002
- Montreal, CANADA
chose between thicker sidewall or bigger rim... not both.
you can always go to 17s.
Tire size question
By nmartin in forum Wheels and TiresReplies: 5Last Post: 10-21-2009, 04:27 PM -
tire size question
By blackz28ls1 in forum Wheels and TiresReplies: 3Last Post: 03-08-2008, 09:10 PM -
Tire size question
By 2000_Black_WS6 in forum Wheels and TiresReplies: 14Last Post: 03-05-2007, 03:48 PM -
another tire size question
By 94transamgt in forum Wheels and TiresReplies: 2Last Post: 06-20-2006, 11:00 PM -
size of tire question
By bbautox in forum Wheels and TiresReplies: 1Last Post: 01-01-2006, 10:41 PM
