Results 1 to 2 of 2
    Joliet
    89 formula -350
    89-formula 350 For Sale Must Go
    Vehicle: 1989 Pontiac Formula 350 ~80K miles White on Gray. Built up for speed and handling with the best components, unfortunately, never got to use that speed. Interior 95%++ mint, original, condition. Missing nothing. Body in good condition, straight, some surface rust on floor pans, body solid. Could use some paint due to normal door dings. Front nose and rear “wing” have cracked paint due to age. Many modifications made and several have been performed and have zero miles on them. Car “project” was started then I had two kids back-to-back (11 months apart) and I haven’t had time to completely finish and, frankly, I’m tired of seeing it just sit and I know I won’t have time to enjoy it. My big loss could be someone’s gain. Car needs to have a heated O2 sensor installed (Bosch, included), a fusible link replaced, a new windshield, and the headers need to be attached to the convertors (3” Random Technologies, included) and the cat-back system. About two months ago I drained the old gas and refilled with 12 gallons of Shell Premium 93 octane gas, and some Stabil, in anticipation of getting the car completed. Well, it hasn’t happened.
    Several parts have been installed but have 0 miles. Also, I have several parts that are still in the boxes. I’ll note those below. Also, the engine was replaced by a GM Pontiac dealer back in 1997 using all NEW GM parts the cost was just shy of $5,000 (only driven about 10,000 miles since). Prior to the engine replacement I installed an electronic pre-luber to the engine. The pre-luber flows 60+ psi through the engine prior to starting. The engine was started about 5 times after replacement without the pre-luber. After that the engine has NEVER BEEN STARTED DRY. This $400 device reduces wear on the engine to virtually nothing. Also, after break-in of about 3,000 miles the engine was always run on full synthetic oil and Mobil 1 oil filters. The transmission was rebuilt around the same time as the engine, by Atomic Transmission in Villa Park, IL, about $1,000. The differential was built by Currie Enterprises and installed by me in about 1998 or 1999, cost over $2,000. All three parts have less than 10,000 miles on them. Specs are below.
    SPECS:
    ENGINE:
    -stock short block new in 1997 ~10,000 miles
    -SLP cam 214/224 duration @ .050 and .470/.490 lift $300
    -AFR aluminum heads 2.02/1.60 64cc chamber, stock compression $2,000. Harland roller rockers stock ratio 1.5 $250. All New, installed, zero miles. Heads bolted on, no additional porting. Approximate compression ratio 9.7:1
    -TPIS Big Mouth $475, Large Tube runners $475, ported plenum $85, 58mm TB $300 All New, installed, zero miles
    -TPIS modified MAF $350, SLP airbox $200, K&N filter
    -SLP 1 ¾” JET-HOT coated headers $900 New, installed, zero miles
    -Dual 3” free flow Random Technology converters $200 New in Box
    3” SLP muffler 3” pipe
    -TPIS under-drive pulley on crankshaft $40
    -180 degree t-stat
    -TPIS adjustable fuel regulator $60
    -Hypertech fan switch on at 200 off at 180
    -stock injectors, cleaned and flowed $280 Just balanced + flowed, zero miles
    -ALL emissions equipment and creature comforts still hooked up
    -3 wire heated O2 sensor $80 New, not yet installed
    -LEVEL V prom chip from TPIS $575 New, installed, zero miles
    -TPIS Pushrods $120 New, installed, zero miles
    IGNITION:
    -stock distributor
    -Crane PS 91 coil
    -MSD 6AL box
    -Taylor 8mm spiro-pro wires
    -New Bosch plugs New, installed, zero miles
    TRANS and DIFF:
    -trans rebuilt, HD clutches, shift kit, 500 over stock stall converter, switch installed to eliminate converter lockup except 4th gear, cooler. 4L60/700R4
    -Ford 9” diff, 3.50 ratio, Trak-Lok, 31 spline forged axles, gears in trans/VSS changed to accommodate ratio change.
    -stock rims and Goodyear GSC tires ~10,000 miles on them
    -TPIS aluminum driveshaft $325 New in Box
    -Transmission has oversize oil pan with drain plug (plug is silicon gooped because I just couldn’t get it to stop leaking, probably needs a new drain plug) Pan allows about 4 qts. extra capacity and has heat sinks on the bottom for cooling.
    -Transmission has aftermarket cooler installed
    SUSPENSION:
    Custom 1” Rear Sway Bar, Links and Bushings to go along with rear diff. >$200
    Front polyeurthane bushings and links $60 New in Box
    Eibach springs, all four corners $230 New in Box
    Super Strut fronts struts, from TPIS $150 New in Box
    GM Heavy Duty rear shocks
    Edelbrock strut tower brace, never installed
    Also included with the car:
    Set of Fel-Pro intake gaskets, New in box
    Set of 8 Bosch spark plugs, New in box
    Several Mobil 1 long oil filters (about 8) All New in box
    Pre-luber with timer
    Factory GM Pontiac CD player, not installed (came from a Grand Prix from same era, looks like will fit)
    Original “chip”
    Battery relocator-rear of vehicle
    Original air dam and bottom nose cover scratched up. Have both pieces-New, never installed.
    ASKING $7000 OBO---THANKS
    Call Chad at 630-709-4030 for more details or to arrange to see vehicle.
    [email protected]
    *****HAVE PICS UPON REQUEST*****
    7 (100%)
    please post an asking price
  1. For Sale: 98 Formula for sale in Wisconsin
    By Mcsful8er in forum Vehicles For Sale / Trade
    Last Post: 05-17-2012, 03:00 PM
  2. 1998 Formula for sale
    By sickspd in forum Vehicles For Sale / Trade
    Last Post: 07-05-2007, 12:46 PM
  3. 2000 formula for sale
    By 00formula in forum Vehicles For Sale / Trade
    Last Post: 01-21-2007, 06:12 AM
  4. 2000 formula for sale
    Last Post: 01-17-2007, 04:32 AM
  5. 94 Formula for sale
    By tparkhi2 in forum Vehicles For Sale / Trade
    Last Post: 10-28-2005, 03:08 PM
