Thread: These mods make a diffrence?
09-16-2006, 10:45 AM #1Member
- May 2006
- New Jersey
Silver- 1998 Trans Am
So i took my car to Car Tech the other day to have an estimate about a full exhaust...and he wanted to drive it so i let him and he said it felt quicker then a stock trans am which i thought it was.....so i called the guy i bought it from nd he said he had put in upgraded valve springs, a vette camshaft, higher quality piston rings, vette oil pump wit matching timing chain and gears......would that make any diffrence? I know some if not most of those are very minor mods but i was just wondering....and car tech mechanics only work on F-bodies....ne info is apreciated! thanks!
09-16-2006, 11:31 AM #2Member
- Sep 2006
- Central,Texas
Navy Blue Metallic- 2000 Camaro Z-28 SS
Well if he is talking about a Z06 cam kit then yes it probably is a little faster and the gears, if you were talking about rearend gears will make it feel faster.
2000 SS #1827,NBM,A4,leather,t-tops,lid,eibach springs,hotchkis lca's,slp lid,slp cold air induction,slp loudmouth,baer brakes up front,13.11@107 on street tires,12.90@109 on dr's....time for the cam and intake to be installed
09-16-2006, 11:36 AM #3
will make a little bit of a difference power wise, but the motor itself will be stronger internally, so you can throw alot more HP at it without breaking shit
09-16-2006, 12:24 PM #4Member
- May 2006
- New Jersey
thanks alots
09-17-2006, 09:17 PM #5
You probably never heard of steroids either?....
09-17-2006, 09:21 PM #6
I'm gonna guess he put an LS6 kit in it. So yes, better than a stock t/a. How much did they want for the exhaust and was that over the axle duals?
09-18-2006, 11:02 AM #7Member
- May 2006
- New Jersey
thanks guys...really appreciate it
Ford 9" Rear, So what mods will I need to make?
By Patsy57 in forum DrivetrainReplies: 3Last Post: 07-02-2008, 02:37 PM -
What is the diffrence between Wet Nos and Dry Nos
By 99Ls1fever in forum NitrousReplies: 11Last Post: 09-16-2007, 05:28 PM -
Best First Mods to make for HP gains?
By Buckeye221 in forum Camaro / SSReplies: 18Last Post: 07-14-2007, 11:10 AM -
Mods to make the ultimate MPG LS1
By TooSlow in forum General HelpReplies: 63Last Post: 02-15-2006, 08:15 PM
