Results 1 to 16 of 16
Thread: Trans Cooler
    Member speedkills's Avatar
    Aug 2006
    Arlington, TX
    1999 Chev Z28 Camaro,
    Trans Cooler
    Does anyone know?
    The trans fluid lines going into the radiator - which line is fluid out of the transmission, the upper or lower line?
    Bragg NC
    Met. Sunset Orange
    01 SS
    I would say the lower line.
    J
    Aug 2006
    MD
    '02 Camaro SS
    I would say the upper line, but the best way to find out is ask a mechanic, the other way is disconnect the lines and see which one the fluid pumps out of.
    Member performabuilt's Avatar
    SUGAR LOAF PA
    blue
    2000ss
    lower line is out on the 4l60e on the trans ,
    Mrs.'s Boobies
    North Hollywood, Ca
    Onyx Black
    Trans Lines:
    Lower = output
    Upper = input
    Cooler Lines:
    Lower = input
    Upper = output (this is to keep all debris in the cooler out of the trans, so fluid rises to the top while debris falls to the bottom)
    George P. Lara
    Mine 2001 Camaro SS #0391: FQuick Garage
    Mrs.'s 2002 Camaro SS #7072: FQuick Garage
    Arkansas
    99 Trans Am
    Quote Originally Posted by 12secSS View Post
    Trans Lines:
    Lower = output
    Upper = input
    Cooler Lines:
    Lower = input
    good info
    Earth
    The line with the rubber hose section is the hot output side from the transmission. As you can see, it enters at the base of the radiator. I know it is the hot line because I made sure of it when I installed my trans temp gauge sensor.
    Hamburg, Germany
    1998 Camaro Z28 A4
    Question
    Question:
    Do the 98 Z28s come with a stock trans cooler, or would that be a mod?
    'Cos then i'd be getting one asap!
    Mrs.'s Boobies
    North Hollywood, Ca
    Onyx Black
    Quote Originally Posted by hamburger68 View Post
    Question:
    All automatic transmission equipped vehicles has OEM transmission coolers. If you are using an aftermarket stall (looser then stock), you will need a bigger or supplementary cooler.
    Hamburg, Germany
    1998 Camaro Z28 A4
    So, longer freeway trips at higher speeds (100+ mph) are no problem with the OEM cooler? I know that here in Germany, a lot of Chrysler/Dodge transmissions have heat problems at higher speeds over longer distances and die prematurely.
    I have a 2.73 rear end, so the engine turns 2500 rpm at 150km/h (95 mph).
    Feb 2006
    2002 WS6
    an aux cooler is never a bad investment, cooler temps = longer life.
    Hamburg, Germany
    1998 Camaro Z28 A4
    that was my thought, too.
    By the way: Great avatar, just saw the movie (an hour ago).
    Arkansas
    99 Trans Am
    Quote Originally Posted by 01Z28M6 View Post
    how hard and how much was your trans temp gauge
    Oxnard CA
    1998 Camaro Z28
    so wich tranny cooler would you recommend? isit hard t install?is it better to cap off the radiator coolerlines and get an independent cooling system for the tranny
    ORNGP33L 1BADDLS1's Avatar
    Long Island, NY
    Hugger Orange
    1999 Camaro Z-28
    B&M off of Thunder Racing works great 24,000 $70
    electric trans temp gauge, autometer $55
    both easy installs with following write ups
    Earth
    Yes, the B&M makes the stacked plate type cooler. These are supposed to be better than the finned tube style, or so I've been told. I could see right away the stacked plates are pretty much immune to smashed fins.
  1. For Sale: mt et street radials/b&m trans cooler/tci deep trans pan
    By senicalj4579 in forum Parts For Sale / Trade
    Last Post: 12-10-2010, 08:34 PM
  2. Trans Cooler for M6???
    By natews6 in forum Manual Transmission
    Last Post: 04-19-2010, 09:26 PM
  3. Trans Cooler.
    By Ryans99LS1 in forum Parts For Sale / Trade
    Last Post: 12-21-2008, 12:00 PM
  4. Trans cooler
    By mysticZ in forum Automatic Transmission
    Last Post: 09-26-2006, 07:51 AM
  5. trans cooler ?
    By lsonecamaro01 in forum Drivetrain
    Last Post: 04-28-2006, 12:31 PM
