Results 1 to 2 of 2
    South Carolina
    1998 Z28 Camaro
    Suspension problem
    Need some advice. I put on the Eibach Pro kit with shocks and full suspension in the rear. But now my car leans to the right in the back. Could it have to do with the panhard bar not adjusted correctly or what. It is a full inch lower on the back right and it is coming very close to my tires. One idea was to get a spacer..not sure about that. Anyone know whats up?
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    make sure you put the isolator on both rear springs when you did the swap. and the spring is centered in the top holder.
  1. 1LE SUSPENSION QUESTION/PROBLEM.... Please.....?
    By NastySS in forum Suspension and Handling
    Last Post: 10-19-2012, 08:31 AM
  2. suspension/ steering problem
    By archer3728 in forum Suspension and Handling
    Last Post: 02-03-2010, 07:27 AM
  3. Question: Problem with suspension?
    By cerneY in forum Suspension and Handling
    Last Post: 11-10-2009, 02:05 PM
  4. Suspension problem?
    By cobrahunter in forum Suspension and Handling
    Last Post: 01-17-2008, 08:36 PM
  5. suspension or tranny problem
    By jonj601 in forum General Help
    Last Post: 04-12-2007, 12:35 PM
