    Laguna Beach, CA
    Red; 58,000 org. miles
    1999 Camaro Z28, M6....
    Chrombs13.....Newbie
    I'm looking to put a programmer on my 99 Z28 and wanted an opinion as to what's the best...DiabloSport, CraneCams, Hypertech, etc.....appreciate the input.........keep rippin'!
    ruff ruff rotwiler's Avatar
    WA State
    LT's, 3400 stall, FIPK,CB
    2002 Z28
    There is a section in the forum for computer/tuning and has alot of info on the different handheld tuners and for the pc. I would stay away from hypertech, not enough parameters to adjust. I use the Predator, but I heard the crane cams one is good also.
    Dec 2004
    SS: NBM, tan top
    1998-SS, 2010 Jetta TDI
    you will also hear that its not worth it till you get a cam or you need it for an auto (shift points) etc.... do the hp/dollar calculation
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    i use the vinci/crane unit. here's a webpage i made about the tuner. http://www.stealthram.com/vhptuner.htm
    Laguna Beach, CA
    Mine is an m6.....programmer or no programmer???
    Member SSmoky01's Avatar
    Central,Texas
    2000 Camaro Z-28 SS
    No programmer. If you want to program it, go get it tuned or buy the HP tuners for your laptop, providing you have one.
    2000 SS #1827,NBM,A4,leather,t-tops,lid,eibach springs,hotchkis lca's,slp lid,slp cold air induction,slp loudmouth,baer brakes up front,13.11@107 on street tires,12.90@109 on dr's....time for the cam and intake to be installed
    Senior Member ninobrn99's Avatar
    Aug 2003
    Honolulu HI
    all bore 370 Trans Am
    read the sticky! thats why i took the time to write it . handhelds are good for a few minor bolt ons and not much more. if you plan on big mods, look into efi or hpt.
    We'll be back... GatorSS's Avatar
    THE SWAMP
    Light Pewter Metallic
    2000 Camaro SS M6
    Ditto...that's why it's a sticky.
  1. Newbie in AZ
    By pdgourno in forum New Member Introductions
    Last Post: 11-11-2008, 03:30 AM
  2. What's up newbie here!
    By Camaro Kid Z/28 in forum New Member Introductions
    Last Post: 09-18-2008, 07:53 AM
  3. newbie
    By nvusone in forum New Member Introductions
    Last Post: 09-13-2008, 01:53 PM
  4. Newbie
    By mwynn67 in forum New Member Introductions
    Last Post: 06-12-2008, 05:34 PM
  5. Chrombs13
    By chrombs13 in forum New Member Introductions
    Last Post: 09-20-2006, 06:41 PM
