    Impounded MikeSomething's Avatar
    Old Bridge, NJ
    Pewter Metallic
    '00 Z/28
    Question Locating VATS Resistance
    Ok, I need a new key for my car, but rather than dealing w/ the "stealership" I'd rather just ask you guys. How can I find out what my VATS resistance number on my key is? Maybe on my VIN somewhere?
    lmpounded SandmanWs7's Avatar
    Dallas, Texas
    2007 CTS-V
    I belive you can use an OHM reader.
    Old Bridge, NJ
    Pewter Metallic
    '00 Z/28
    Quote Originally Posted by sandman22 View Post
    I believe I can't. I'm OHM ignorant.
    LS1ftmfw
    Jun 2006
    spfld mo
    Navy Blue
    99 ws6 trasns am
    You should be able to give gm the vin and a jar of vasoline and take it up the ass for a key, when you get one from gm they are gonna want proof of ownership, copy of the title, copy of your drivers license (or personal photo id) the length of your d*ck also... there isnt really any way to buypass vats, If your lucky and dont get a FukTard on the phone he might give you the chip Number. Theres only 12-14 different chips so...
    Do you have a multimeter? If so just put it on the ohm setting Ω and touch one lead to one side of the pellet and the other lead to the other side and record the ohms. A multimeter can be had at autozone for ~$20.
    Philadelphia, PA
    2000 SS
    Quote Originally Posted by MikeSomething View Post
    Just check around at your local hardware stores. Some of them cut Vats keys. I just had mine done and it was $19.95
    Roseville, CA
    05 Wrangler
    00 Z28 sold :-(
    do the bypass and be done with it..then get a alarm with starter kill and a back-up battery
    near St. Louis
    navy blue
    2002 Z-28 Camaro M6
    agreed-my local hardware store makes these keys also for around $20. VATS is a good system as long as it is operating properly-just get a new key.
  1. Need help locating ...............
    By 9T8WS6 in forum Suspension and Handling
    Last Post: 04-22-2012, 04:55 PM
  2. VATS????Security problem with the VATS.
    By LS1RacerMan30 in forum General Help
    Last Post: 07-14-2007, 07:39 AM
  3. Need help locating performance shops in Detroit
    By joe77 in forum Camaro / SS
    Last Post: 09-08-2006, 09:39 AM
  4. Locating the star connector
    By Some Call Me Tim in forum General Help
    Last Post: 06-19-2006, 04:28 PM
  5. need help locating a part in engine
    By TAmamma in forum Computer & Tuning
    Last Post: 11-07-2005, 09:05 PM
