Thread: Headlight Problem Need Help
09-08-2006, 11:11 AM #1
I Have A 2001 Ws6 This Just Started The Other Day.when I Push The Lock And Unlock Button On My Keeylessentry My Head Lights Go Up And Down And After They Go Back Down The Driverside Motor Stays Running For About Ten Seconds After The Light Is Closed Could It Be The Motor Or The Relay That Mounts Under The Hood On The Side Of The Fusebox.
09-08-2006, 04:47 PM #2Junior Member
- Nov 2005
- ga
blue- 1998 trans am
Try this link...
http://www.bfranker.badz28.com/headlightfix/
This link has the info you need. You can replace the nylon gear with a brass gear or you can replace the entire motor assy. Your choice?
I went the brass gear route.
09-08-2006, 07:58 PM #3Junior Member
- Aug 2006
- Houston
Red- 00' Formula
http://my.execpc.com/C4/4A/rodney1/firebird/
same thing happened with my car. bought the brass gear, and the problem was fixed. buying the gear is alot cheaper than buying a new motor.Last edited by cptncdy; 09-08-2006 at 07:59 PM. Reason: added link
09-12-2006, 07:50 AM #4Junior Member
- Jul 2006
- Sunnier Yuma Ariz
Navy Blue- 2001 Trans Am WS6 Vert
Same problem last month. For a temp. fix get the headlights up. By either manual lift or motors. Then unplug the headlight control modulator.... Located next to the fuse block on the drivers side. One plug has 5 wires other has 4. After you unplug the controller the head lights will stay up but all other functions are retained.
09-13-2006, 03:04 AM #5
Heh.... mine just started doing the same thing a couple of days ago
09-14-2006, 09:26 PM #6
You can also try flipping the gear. Instructions on doing that are at ben franker's site. I hope that guys made a killing off of his fix because he's helped a ton of people with their headlight issues. Including me. I put his brass gears in a month or so ago.
09-16-2006, 05:22 PM #7
I was lucky...my passenger side one caused it on mine, but it was under warranty. I convinced them to also replace the driver side one at the same time because I said, "the driver side motor is now slower than the passenger side one, so it must be weak as well".
No problem since. I suspect I will see the problem again eventually, but I figure when that time comes, I'll be going for those brass gears as well. Sounds like the best way to go.
11-17-2006, 11:07 AM #8Junior Member
- Mar 2006
- OC CA
I can understand the brass gears being better, but what causes the headlights to open and close prior to the grinding? I had this problem on my 98 prior to the warranty ending, but don't recall what they did to fix it. Unfortunately, it's doing it again so I need to figure out what the problem is and fix it myself.
Any clues? Is there some kind of electronic component that triggers the lights to open/close that has gone bad?
11-17-2006, 08:08 PM #9
There's been a few discussions on this. I'll try to find the explanation I read that seemed to make the most sense.
HEADLIGHT problem!!
By stefos in forum Firebird / WS6Replies: 9Last Post: 08-31-2010, 08:29 PM -
Question: headlight problem
By INFERNO T/A in forum Firebird / WS6Replies: 7Last Post: 08-29-2009, 07:10 AM -
headlight problem
By gofast in forum Firebird / WS6Replies: 5Last Post: 09-10-2008, 09:55 AM -
headlight problem
By supercampeones4 in forum Stereo and ElectronicsReplies: 2Last Post: 05-08-2008, 08:17 PM -
Headlight Problem
By Wesman in forum Firebird / WS6Replies: 8Last Post: 08-22-2007, 07:55 AM
