    Drive it like ya stole it sills1's Avatar
    San Diego, California
    Lowering Project
    Well, after several weeks of staring at my Koni SAs sitting in the floor, I finally installed them today with the help of Ed Blown Vert and JD_Z28. Ed supervised and JD helped turn a few wrenches. A big thanks goes out to those guys. I used the lower perch on the Koni's and did the hose mod on the back. There isn't much difference in ride height that I can tell so far, but just for the sake of whoring my car, I thought I would post some before and after shots. I'm hoping the car will settle and sit a bit lower after a few days.
    BEFORE......
    After.....
    MEMBER 5150's Avatar
    Visalia Cali
    SILVER
    2000 Z/28
    looks better but i would go a little lower but that just me.
    Senior Member Hurley711's Avatar
    Earth
    414 RWHP 395 RWTQ
    00 Black Ram Air Trans Am
    Hose mod is great free mod noone really talks about...it dropped my rear a full inch..yes 1 inch in the back for $7 and 1 hour worth of work
    I've been told it will drop a bit more after I drive the car a couple of days. It just needs to settle a bit, I hope that's what happens.
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    Looks good, I need to do that to my rears now.
    Forged 383 | ATI D-1SC
    NX MAF Kit | 222/226 .585 115
    AS Stage II 6.0L FI Heads
    Problem with the rear sitting evenly. The driver's side is about 1/2 inch higher than the passenger side. I can stick 4 fingers inbetween the fender well and the tire on the driver's side and only 3 on the passenger. Anyone have any ideas. I jacked up the car on the driver's side and looked at the spring and it is seated right on top and bottom.
    Aug 1999
    No Where
    I thought the Driver-Side was always a bit higher. Then once the driver gets in. It levels out.
    Visalia Cali
    SILVER
    2000 Z/28
    My car was doing the samething until i put on an adjustable panhard bar. when i lowerd it the factory bar was to long causing the drivers side to sit slightly higher and the rearend had moved over to the passenger side slightly. Once i put the new bar in and centered the rearend the car sat fine. Btw i just used springs to lower my car.
    I started looking at some old pictures of my car and recognized a difference between the driver and passenger side. It looks like I was unaware of a pre-existing difference from side to side. Maybe there isn't anything I can do about this difference in ride height, but I'm going to try and figure something out.....it's driving me nuts.
    Here are the old pictures I am looking at.
  1. Project F73 Chevrolet Camaro - Project Cars
    Last Post: 09-13-2012, 07:40 PM
  2. Project Chevrolet Guide - Project Cars
    Last Post: 09-27-2011, 06:20 PM
  3. My Lowering And Suspension Project
    By j nix in forum Suspension and Handling
    Last Post: 05-24-2011, 01:17 PM
  4. Project 1979 Chevrolet Camaro Z28 - The E-Rod Z28 - Project
    Last Post: 11-23-2010, 04:30 PM
  5. Replies: 0
    Last Post: 04-10-2007, 11:00 PM
