Results 1 to 10 of 10
    Bad habbit- Smoking Fords
    South Florida
    Sunset Orange Metallic
    Found! Head light conversions for LT-1 Camaros/Firebirds
    I came accross this place just browsing and thought it might be interesting to some of you.
    http://eurolamps.com/eurolamps/camaro_headlights.htm
    2001 SS - 430 RWHP 412 RWTQ
    6 spd, FIPK, Corsa exhaust, LS7 clutch, Dart Pro PP LS1 heads, custom 220/224 cam, Kooks LT's. Ported TB, Full suspension, C5 ZO6 brake upgrade.
    sped
    Guest
    Nice find!
    I wouldn't mind looking into getting these someday.
    Junior Member MCH SS's Avatar
    Ms
    Bright Red
    I had a kit from that place on my T\A,good qaulity.
    sped
    Guest
    Quote Originally Posted by MCH SS View Post
    That's good to hear. I was a bit skeptical because it seems decently cheap.
    Senior Member Redphoenix1998's Avatar
    Apr 2002
    San Jose
    1998 Pontiac Trans Am
    that's some good quality stuff. I got mine from there a long time ago
    Junior Member Thegr8schlotzky's Avatar
    Jun 2006
    Salem, Oregon
    1996 Camaro
    So that is a true HID conversion? that seems too cheap for a conversion..is it just a lot better bulbs or are the other kits i've seen just really overpriced?
    Member cobrahunter's Avatar
    South Bay
    1998 Camaro Z28
    I got a set of these for my mom's 97 Camaro. The bulbs are not TRUE xenon HIDs, since they don're require ballasts/ignitors; almost like hyperwhite bulbs. The main reason I would think someone would go with this kit that it allows you to change out JUST the bulb; as opposed to the entire glass housing, that is stock on all pre-97 Camaros. That's why I got them.
    Aug 2006
    WV
    1999 Z28 M6
    I made the same thing for alot cheaper for my 96 Camaro. I just used my bulbs I already had in the car, pulled the element out, cleaned the housings up, and used 9005 and 9006 bulbs and it worked great and was way cheaper. The bulbs are a direct swap. It's best to find stock bulbs with the clearest, least textured glass possible for the best results. I also put the clear flush mount headlight covers on mine to protect the bulbs from rock chips. there are pics on my cardomain. I have since updated to the Hella FF75 conversion, but the car is for sale now and I don't even drive it anymore. Both upgrades were a great imrpovement over stock, but the Hella's were best.
    The headlights: http://www.cardomain.com/member_page...03_25_full.jpg (don't think I can post images yet)
    The FF75's/clear covers: http://www.cardomain.com/ride/693103/9
    Jun 2006
    Streamwood, IL
    1997 Trans Am
    These are not true HID conversion (although they do sell one for about $300.)
    There is a replacement glass projecter that looks like the factory sealed beam light, and a bulb. You plug the bulb into the factory wiring, put the bulb inside the projector and put it all back together like stock. It is a dual element bulb, so the high beams still work too. They also sell matching bulbs to replace the fog light bulbs.
    I just installed mine, and have a small problem. The passenger side does not work correctly. It comes on, but does not light up nearly as bright as the drivers side. I did pull it back out and double check the connections to ensure they were creating a good electrical connection and it looked good. I sent the company an e-mail asking for assitance, but thought you guys might have some insight.
    Any thoughts?
    Jun 2006
    Streamwood, IL
    1997 Trans Am
    Well, I am an idiot. I tested the headlight without it mounted. The headlight needs to be grounded through the housing. Fully installed, it works like a charm. VERY bright. I like it alot.
  1. Hot Wheels Firebirds,Camaros,Vettes & more! (ebay)
    By Firebird Phoenix in forum General Classifieds
    Last Post: 02-28-2010, 01:48 PM
  2. Firebirds (and Camaros) Need a lot of A/C?
    By clovenhooves in forum General Help
    Last Post: 08-26-2009, 08:00 PM
  3. Parts 4 Firebirds/Camaros & etc!(Ebay NO RESERVE)
    By Firebird Phoenix in forum Parts For Sale / Trade
    Last Post: 04-12-2009, 07:40 PM
  4. Rims for Pewter Camaros/Firebirds?
    By Styke in forum Wheels and Tires
    Last Post: 10-23-2007, 08:58 AM
  5. looking for johnny lightning firebirds ta's and camaros
    By balls51 in forum General Classifieds
    Last Post: 04-26-2006, 09:15 AM
