Page 1 of 3 123 LastLast
Results 1 to 20 of 56
    Senior Member Redphoenix1998's Avatar
    Apr 2002
    San Jose
    1998 Pontiac Trans Am
    Differences between the f-body years
    Some info posted a while back. Very useful info thanks to third_shift studios.
    Thanks for the info Jaison
    1998 F-Body
    1. Had different casting heads which had perimeter bolts and valve covers.
    2. Ignition coils were mounted to the valve covers one at a time.
    3. The water temp gauge actually works.
    4. 98's do have an oil life monitor, they just don't tell you anything when its time for a change. You can find it in Auto-Tap
    5. WS6s had single outlet exhaust (all others had duals)
    6. Steering wheel controls were completely different part with indentations on the buttons, and were better built
    7. Only year that Purple, Gold, and Green were available
    8. Some very early Trans Ams came with LT1 style headrests
    9. Rear hatch release was poorly designed and often caused problems releasing mechanism
    10. Early model 98 Monsoon stereos didn't have capability to control 12-disc CD changer
    11. 1998-1999 automatic transmission LS1s could be started in 1st gear even with the shifter in 2nd. Starting 2000, if you put the shifter in 2, it would start off in 2, even from a stop.
    12. 1998-1999 LS1 cars had a smaller throttle body cam, which caused the throttle to open to WOT (wide open throttle) faster than 2000+ cars
    13. 1998 cars had 28 lb fuel injectors from the factory
    14. 1998-2000 cars had a larger cam than the 01-02 cars
    15. 1998-1999 cars had more restrictive exhaust manifolds
    16. 1998-2000 cars had an LS1 intake with EGR
    17. 1998 and some early 1999 cars had blue outside rear view mirrors (Trans Am only)
    18. 1998 only LS1 blocks had a much smaller cylinder sleeve that only tolerated a .005" hone
    19. Last year F-body to use the old 15.5 gallon steel fuel tank.
    20. Only year LS1 F-body to contain a gas cap with a tether long enough to actually hang from the fuel door while open
    21. Only year LS1 F-body to not contain the famous GM black box used in the event of an accident to record up to 5 seconds of pre-crash data
    22. 1998 only cars had a different PCV system with the PCV valve located above the passenger side valve cover
    23. 1998 most cars did not have an idle adjustment screw on the throttle body. Some 98 cars do have the idle throttle stop set screws.
    24. 1998 cars have a completely different PCM from 99+ cars
    25. A production shortage of F-body cams caused the use of a C5 cam to be installed in F-body LS1s for a very short time
    26. 97-98 LS1's used a paper water pump gasket. The only gasket that isn't reuseable
    27. SSs did not ALL go to SLP starting in 98. Y2Y was the RPO code that sent them to SLP for additional options
    28. SS option did not "include" the Synthetic oil package, it was a SLP only Option
    1999 F-Body
    1. 1999-2000 cars switched to 26 lb fuel injectors
    2. Cylinder heads and valve covers redesigned to have center bolts instead of perimeter bolts. Other than that, the heads were the same.
    3. Redesigned cylinder sleeves that allowed for a small bore, up from .005" in 1998 models.
    4. Midyear model change to a cheaper steering wheel audio control button without finger indentations, and cheaper built
    5. 1999 cars continued the LS1 intake with EGR provisions
    6. 1999 cars continued more restrictive exhaust manifolds and larger cam
    7. Only year that Hugger Orange was available (Camaro only)
    8. 30th Anniversary Trans Am available with special blue and white paint package and blue clear coated WS6 wheels
    9. Switch to larger 16.8 gallon plastic fuel tank to meet new emissions requirements.
    10. Gascap tether was shorter and could no longer be used to hang on the gas door when open.
    11. Company wide change added black boxes to record up to 5 seconds of data before a crash
    12. Rear hatch release was redesigned with stiffer spring that released the hatch better
    13. Water temp gauge was redesigned to work basically as a dummy gauge and only show an overheat condition.
    14. An oil life monitor was added to all LS1s, thus changing the gauge cluster a little to show the oil life reset swtich
    15. 1999-02 cars had a different PCV system with the valve located to the side of the intake manifold
    16. Early production 1999 Trans Ams still had the blue outside mirrors, but a midyear change went to the non-tinted ones
    17. 1999 there was the color "Medium Blue Metallic" which was available on both the Camaros and Firebirds. Only one year of that color
    2000 F-Body
    1. Redesigned exhaust manifolds for new emissions standard actually flowed better and created a little more HP.
    2. 2000 continued use of LS1 Intake, EGR, smaller cam, and 26 lb fuel injectors
    3. Added rear child seat safety hooks to interior per federal requirements
    4. Very early run of WS6s had "salad shooter" style rims. A production change switched back to standard 5-spoke WS6 rims.
    5. Camaros got redesigned 10-spoke base rims, and SSs came with new 10-spoke rim design
    6. First year of Monterey Maple Metallic paint
    7. Charcoal (grayish) interior was replaced with Ebony (almost black) leather interior
    8. Cloth interior cars got new rainbow colored cloth patterns
    9. Camaros only got the Pontiac steering wheel with optional audio controls
    10. Throttle body cam was increased in size to slow the speed at which the car reaches WOT
    11. Automatic transmission cars were reprogrammed to allow a car to start off in 2nd gear from a stop when the shift lever is put into 2.
    12. The last year a WS6 Formula was offered
    13. Starting 2000 intake lids contained a seperate breather filter
    14. 2000+ Camaros came with body colored mirrors instead of black ones like 98-99
    2001 F-Body
    1. A small percentage of 2001 and 2002 LS1s actually had LS6 blocks which had a different part number and a darker metal cast
    2. Starting 2001, all LS1s came with an LS6 intake manifold without an EGR system
    3. Advertised HP output was changed from 305 to 310 on base LS1s and from 320 to 325 on WS6s and SSs
    4. 2001-02 cars have a smaller cam from the Vortec truck engines to increase low end torque
    5. 2001-02 cars had 28 lb fuel injectors like the 98 cars (albeit different part numbers)
    6. WS6 cars had a redesigned 5 spoke rim which was more wavy
    7. WS6 cars got less suspension upgrades from a base Trans Am suspension than previous years
    8. Manual transmission cars all came with the Z06 clutch
    2002 F-Body
    1. 35th Annivesary edition of the Camaro, and Collectors Edition Trans Am available
    2. 2002 LS1 head gaskets redesigned. The new ones are a pressed metal, as opposed to the graphite ones and are no longer specific to the side of the car theyre installed on
    3. 2002 cars continued with the LS6 intake, 28 lb fuel inectors and smaller truck cam
    4. 2002 continued the use of an LS6 block in some LS1 F-bodies
    5. A factory supported optional 345 HP option could be ordered from SLP
    6. Manual transmission cars continued use of the Z06 clutch
    7. Some 2002 model F-bodies came with a revised rear view mirror that had the map light buttons on the bottom, rather than the front.
    my pleasure =)
    Custom Car Emblems
    from third_shift|studios
    jaison tortorea
    everywhere
    2000 Trans AM WS6
    hi i had a quick question. do 1998-2002 trans ams use the same body parts size/length/width wise (font bumper, fenders, hood). i have a 2000 ws6 and i basically need a front clip. i was wondering which years were compatible. thanks.
    Philly area
    I was able to use a 2001 Trans Am WS6 rocker panel on my 1999 Trans Am.
    I just had to peel off the old paint and repaint using the factory paint code.
    I bet most of the exterior and interior parts will match across years.
    everywhere
    2000 Trans AM WS6
    sweet thanks djvaly. (lovin the banana).
    99firebird-ta fredy's Avatar
    Feb 2006
    daly city
    99 pontiac trans am
    how about 99 camaro how many hoses are a the wheel with stock engine
    nothing special yas stock engine ....
    rwhp stock..
    Feb 2006
    daly city
    99 pontiac trans am
    anybody knows
    thankssssss guys..
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    ls1 make 350ish to the fly...becuase of tolerances it can range between 280-320 (320 are factory freaks!) since yours is a 99 it would prob be 280ish to 300ish to the wheels but its hard to tell
    mods- suncoast creations hood with functional lt1 style airbox, ls6 intake, QTP longtube headers, QTP ORY, UMI SFC, Adj. LCA with relo brackets, UMI adj. panhard bar, Koni SA and strano springs,Torq Thrust M 17s 9.5 and 10.5 with nitto 555Rs, tuned by Frost
    Quote Originally Posted by Modulistic View Post
    sometimes you get owned, sometimes you own.
    Feb 2006
    daly city
    99 pontiac trans am
    thankssss for the advice.....
    so is 275hp to 280 stock engine to wheel nicesssssssss
    Shepherd, Michigan
    98' trans am
    well yea...but i'm trying to get 350 to the wheel
    Feb 2006
    daly city
    99 pontiac trans am
    well i got 385 rwhp but i had cam header ls6 intike 30lbs injector a airflow 78mm asp pulley
    custom tune 5.0 shirter k&n filter cone stiles .....
    my car is 99 trans am
    what you think about this set up let me know if is good....????
    Shepherd, Michigan
    98' trans am
    man you need sfc right away..but yea it sounds good..is it a a4 or m6?
    Feb 2006
    daly city
    99 pontiac trans am
    good deal ?????????????
    Shepherd, Michigan
    98' trans am
    Quote Originally Posted by fredy View Post
    ?? good deal what?
    Feb 2006
    daly city
    99 pontiac trans am
    not sure what is sfc cant you tell me please...
    i got m6
    Shepherd, Michigan
    98' trans am
    sub frame connectors...they help limit boy flex...you need those asap..then for your tranny..you need a z06 clutch or spec3 clutch..um update the hydrolics to the 01-02 style. and you'll be golden..if you don't miss alot of shifts
    Feb 2006
    daly city
    99 pontiac trans am
    well i got a ram cluth hd..
    from summitracing.com
    Philly area
    yeah, if it's A4 like mine then substract 18% to 20% from the engine hp and you get hp to the rear wheel. The M6 are said to be about 16% power loss..
    so let's take my '99 A4 TA which claims 305hp to engine. That means
    305-(305*0.18) = 304-54.9 = 250.1rwhp as stock engine.
    I've got bolt on mods, lid and filter (5rwhp), SLP cold air induction kit (8rwhp), smooth bellow (5rwhp), Gratenelli MAF (5rwhp), 160F thermo, cat back Corsa (15rwhp), HyperTech Programer II (10rwhp), ASP Underdrive Pulley(12rwhp).
    This dynoed the car at 315wrhp. so all those bolts on gave me only about 60-65 rwhp gain which is just about right. I did spent $850 on the Corsa, then $250 on the HPP3, and then another $300-$400 on the rest, about $1500 total which is about right for 60rwhp gain. If you were to spend $2000 on new head cyclinder it would bump you 50-60rwhp so I think I made a pretty good investment so far on the bolt ons.
    My next move is to get jet-hot long tube haders and Y pipe which will add 20-25rwhp and then
    get ls6 manifold intake adding another 10rwhp. And when I get $2-3k aside next year I can get the
    head/cam package Patriot stage III probably which will get me in the 420rwhp with a nice tune.
    PS. I did get the Eibach Pro kit lowering 1.25, it looks great.. use the stock shocks as you won't bottom out with this unless you go with 2inches springs.
    Shepherd, Michigan
    98' trans am
    negitive..your ls1 is around 350 to the crank..they 305 bullshit was gm underrating them. most cars dyno around 280-320 to the wheels
    Philly area
    per "99blueZ" on another thread, so ya "shady" you are probably right as well.
    "Way to open up a ancient thead.
    Ok you got some problems with your post. Your T/A probably has about 330 crank hp stock - these cars are underrated. You car stock is probably 280rwhp. Thus you gained about 35rwhp from your mods. 315-280= 35. not the 60+ you were dreaming of. Here are the more realistic gains for your mods: lid and filter -10rwhp, SLP cold air induction kit -0rwhp, smooth bellow -0rwhp, Gratenelli MAF -0rwhp, 160F thermo, cat back Corsa -15rwhp, HyperTech Programer II -0rwhp, ASP Underdrive Pulley -10rwhp."
  1. Help: 98-02 F Body Engine Differences?
    By mammoth713 in forum Camaro / SS
    Last Post: 12-07-2010, 07:01 PM
  2. Differences between the f-body years
    By Redphoenix1998 in forum Camaro / SS
    Last Post: 09-11-2010, 07:30 AM
  3. Differences between the f-body years
    By Redphoenix1998 in forum General Help
    Last Post: 02-27-2009, 07:10 AM
  4. Differences in years?
    By Semperfiws6 in forum GTO
    Last Post: 01-01-2008, 06:38 PM
  5. LS1 differences through the years
    By third_shift|studios in forum Firebird / WS6
    Last Post: 01-29-2006, 12:55 AM
