    San Diego
    2001 WS6 Pontiac TransAm
    How hard is it to change out a radiator on a 2001 Trans Am?
    I have to replace mine. Mine has a crack thats an inch long that I've tried patching, both with the things you pour into the radiator and with some JB weld. Its on the Rt passenger side about 3 inches below the top. So, whats the time frame im guessing 3 to 4 hours? Any lessons learned if you did it yourself? Thanks.
    Senior Member
    Jacksonville, FL
    Never changed one, but when doing my FTRA install the radiator was loose up top after removing a few bolts - without the hoses connected probably would've fallen out. Go for it, shouldn't be hard at all.
    Retired Outlaw Sum Bitch
    Common sense and a set of wrenches your good to go.
    Don't even really need the common sense.
    Very simple.
    Drain and replace.
    Be careful with the clips that hold everything together. Those can be a little bit of a pain...but be patience and it should be pretty easy.
    Member Sunset T/A's Avatar
    Spring, TX
    Sunset Orange
    2002 TransAm
    Piece of cake.
    2002 Sunset Orange TransAm 6 spd.
    http://www.mustangmods.com/data/1327/dadsigpic2.jpg
    VA
    WHITE
    2000 CAMARO
    2 hours max
    San Diego
    Thanks everyone! I was almost going to take it to a shop cuzz I didnt want to deal with any hassles but sounds pretty straight fwd. Thanks.
    Junior Member 120inna55's Avatar
    Athens, TX
    Sorry to dig up an old thread, but my radiator has a leak in the same place as the original poster's---only mine seems to be only about 1/4".
    1. Should I try to patch it?
    2. If so, with what?
    3. It appears to be plastic. Is it really plastic???
    4. Otherwise, how much should I expect to pay a shop to replace it? (parts & all)
    Thanks for helping a newb.
    you could try to patch it with some plastic weld but my experience has been that stuff rarely holds and if it does it's on borrowed time. Look on here for a used radiator from lsx_heaven and do it yourself. You really only need a couple of hand tools and it's a very easy job..... I could walk my wife through it if that tells you anything.
    Member slpdablueZ28's Avatar
    Sep 2008
    brooklyn
    blue
    2002 Camaro Z28
    i think they patched a radiator by cracking an egg into it on mythbusters. but i dont recommend doing that
    Quote Originally Posted by slpdablueZ28 View Post
    nothing like having egg floating around in the coolant passages. I wouldn't recommend that either.
    Sep 2008
    brooklyn
    blue
    2002 Camaro Z28
    eggs ls1 anyone?
  1. Replies: 3
    Last Post: 08-30-2016, 08:35 AM
  2. Help: Radiator fluid change
    By MRivera in forum General Help
    Last Post: 07-17-2011, 07:38 AM
  3. How hard is to change the pinion seal?
    By JayTA98 in forum Drivetrain
    Last Post: 07-11-2010, 10:34 AM
  4. How hard to change 160 ' T-stat? Looking f/advice
    By 5abivt in forum General Help
    Last Post: 08-14-2009, 06:41 PM
  5. Radiator swap.. is it hard to do???
    By blackTA6585 in forum External Engine
    Last Post: 08-17-2007, 08:56 PM
