08-28-2006, 02:10 PM #1Junior Member
- Aug 2006
- Hi
Does a turbo affect your gas mileage any?
If I remember correctly, not all turbo installs require new fuel injectors or fuel pumps. In this situation would a turbo negatively affect gas mileage?
08-29-2006, 12:22 PM #2
08-29-2006, 01:20 PM #3
it depends on how fast you want to go, or how often you are using the turbo, if your turbo spools and creates more dense air , your ecu will give it more fuel for MORE POWER!
09-01-2006, 02:08 PM #4Junior Member
- Temecula, CA
Yes a turbo will affect gas milage. A turbo is no different than a normally aspirated motor, it just makes power in a different way.
Remember any hp level requires a certain amount of fuel to make the power.
If you are in boost you are using more gas to make the power. If you are not in boost you are not using any more gas than you normally would.
The nice part is that your right foot determines your gas milage.
09-01-2006, 11:21 PM #5Junior Member
- Dec 2005
- Woolwich Township NJ
Yellow w/ flames- 2004 GTO
I don't have to tell you the biggest effect of gas milage is your right foot. Seriously I have recently installed a STS rear mount on my 04 GTO and on the highway keeping it at 65 it gets 21mpg. That's with 3:91 gears and the ls1 hot cam. The turbo really did not change the highway mileage as much as the cam dropped from 23 to 21. City milage is crap but I think that is more to my wanting to hear the turbo spool up.
09-02-2006, 06:09 AM #6;)
- Apr 2001
- Surf City, NC
Black/Screaming Yellow- 99 S/C TA WS6 & 04 Cobra
That statement right there is right on! Most of these LS1 cars that don't have big cams in them will get good gas mileage as long as you don't floor them everywhere you go! Even the A4 cars provided you have the right stall for your application and you are not flogging her everywhere you go! My car got like 24 mpg when I drove it to ATL for the F-body Gathering this year. It is all on the driver and how he regulates the gas! My in town mileage is crappy but on the highway I just throw her in 6th, set the cruise, and let it ride!!!
1999 Trans Am WS6 Black - Forged 346, P1SC (8psi), TH-400, and 12 bolt(3.73's)
10.29@129 w/1.60 sixty foot
2004 Screaming Yellow Mustang Cobra - Whipple 2.3, Exhaust, & CCW's...My DD
09-03-2006, 07:34 AM #7Junior Member
- Sep 2006
- Lexington
Black- 87 Buick GN
09-04-2006, 12:27 PM #8Junior Member
- Mar 2006
- Regina, Sask Canada
Black- 2000 Camaro SS
my ls1 camaro has got good millage, just driving around being easy on the car i get 19-21 per tank in city only driving conditions.
i still havent taken a trip on the highway so im unsure of those numbers.
but i remember before with my stock motor i only use to get 17 around town without the turbo.
but i agree, a good tune will put you where you need to be as far as proper fuel delivery.
then when im spooling and boosting the car its a whole other story the car just loves the fuel and i have to drive from station to station.
09-11-2006, 07:49 PM #9Junior Member
- May 2006
- Indiana
Silver- 1998 camaro z28
Correct me if i'm wrong, but I believe that the question was geared more toward if under normal driving conditions, would a turbo cause your mpg to decrease. The only parasitic loss from a turbo is the backpressure, so the loss would be so small you wouldn't notice. Now with a supercharger you probably still wouldn't notice, but it would be lower due to the engine having to move another accessory, kinda like having your air on.
oh yeah, and no matter what you do to a car, if you floor it, your going ot use more gas. So you can't say "yeah a turbo is going to cause your mpg to go down, because your gonna stomp on it!" It's the same freaking thing if you stomp on a prius :P
09-11-2006, 09:16 PM #10
I dont know too much about turbo charged LS1's but with ricers and 4x4 trucks... Turbos SAVE gas under normal driving conditions... Unless you use it. then common sense tells you otherwise
09-12-2006, 08:08 AM #11Junior Member
- Mar 2006
09-15-2006, 07:35 PM #12
Oh darn. It's the RIGHT foot!!!
Question: Does post cat oxygen sensor affect gas mileage?
By DarthD in forum General HelpReplies: 12Last Post: 06-07-2015, 06:52 PM -
How does LSA affect performance?
By Spikito in forum Internal EngineReplies: 20Last Post: 09-25-2012, 11:17 AM -
Help: Will this affect me?
By clg82 in forum Firebird / WS6Replies: 0Last Post: 06-11-2009, 08:20 AM -
How much would a small turbo affect MPG?
By xinthenight in forum Forced InductionReplies: 5Last Post: 02-08-2008, 03:25 PM -
How Much Would Theft Recovery Affect Value?
By CJREX in forum Camaro / SSReplies: 7Last Post: 11-04-2007, 02:35 AM
