08-27-2006, 06:04 PM #1Junior Member
- Aug 2006
- Toronto, Canada
Black- 1999 Firehawk TA Conv.
Traction Control and P0121 SES problem
Hello. I am a new member to this forum. I have a Black 1999 Firehawk Trans Am convertible (Car# CO99 for Firehawk fans) and look forward to checking out this great forum!
So while on my drive from Toronto to the Dayton, Ohio Trans Am Nationals this weekend, the TCS light came on while at 70mph a few times as well as the SES engine light. The error code I am getting is P0121 which means "Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance Problem" from my ODBII scan tool. Not sure where to start with that one ;-)
I am assuming (and hoping) these two issues are related. Does anyone have any ideas. I am thinking it is some speed related sensor as the TCS light comes on after 60MPH. I checked the fuse for the TCS and it is good.
Apreciate any help.
08-28-2006, 09:59 AM #2
do you have a scan tool or a code reader?
08-28-2006, 11:37 AM #3Junior Member
- Aug 2006
- Toronto, Canada
Yes, as mentioned, my code reader spit out the following for error code P0121which means "Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance Problem".
08-28-2006, 11:45 AM #4
Just to rule out the obvious: What size wheels/tires are you running?
08-28-2006, 01:10 PM #5Junior Member
- Aug 2006
- Toronto, Canada
Running stock 17" Firehawks.
Help: abs; traction control
By JUSTINCOLSON145 in forum GTOReplies: 5Last Post: 10-23-2013, 02:54 AM -
Traction control on/off
By Lunatikgixxer in forum Firebird / WS6Replies: 22Last Post: 03-24-2011, 09:25 AM -
cruise control with traction control
By basballny2 in forum General HelpReplies: 12Last Post: 06-16-2010, 11:57 PM -
Traction Control problem...quick help?
By Racquetballryan in forum Firebird / WS6Replies: 1Last Post: 10-15-2006, 05:35 PM -
traction control
By gillahoon in forum Firebird / WS6Replies: 19Last Post: 07-20-2006, 01:58 AM
