Results 1 to 2 of 2
09-12-2005, 12:55 PM #1Junior Member
- Phoenix
Blue- 1995 Caprice
LQ4 Pinout question (Fuel Enable- circuit 229)
I have the pinouts for the PCM but I can not find or see the pin for the fuel enable signal?
Did a search and can find it on the LS1 2002 (red 30, circuit 229) But looking at the pinouts for the truck PCM (the copy I have) it does not show a fuel enable or a circuit 229 ?? I was going to build the circuit as a temp solution until I get car to a place for programing or ship PCM off. Just got it fired up this weekend and runs for about 2-4 seconds. Wanted to get it to run longer so I could do some checks,, Leaks,,tranny goes ingear ,,ETC... Anyone have A suggestion let me know THANKS ,, Roger,,
09-20-2005, 03:52 PM #2Junior Member
- Warsaw
- Lots
These have serial vats, you have to pull the vats off in the computer to let it work.
if the pcm was a pwm you could make up a signal, but it is pretty cheap to get it deleted from your system.
Firmware maker says it could enable dual-boot Windows RT, An
By Ed Blown Vert in forum Computers / GamingReplies: 0Last Post: 09-13-2012, 11:41 PM -
short in fuel pump circuit
By TryMe in forum General HelpReplies: 0Last Post: 07-09-2009, 06:58 PM -
02 Ls1 Ecu Pinout????
By nmssr08 in forum Computer & TuningReplies: 2Last Post: 08-15-2008, 12:58 PM -
PCM Pinout Needed
By jeffreystar in forum Computer & TuningReplies: 6Last Post: 01-02-2007, 12:21 PM -
Anybody have an ecm pinout for an 03' c5?
By Me gags in forum Computer & TuningReplies: 2Last Post: 11-18-2006, 12:04 PM
