Thread: SLP Sub Frame Connector Help!
09-12-2005, 08:57 AM #1
- Macomb, Mi
Red- 1999 Trans Am
I just recently acquired a set of SLP Sub Frame Connectors (Bolt In) for the TA however, they did not come with any hardware. Does anybody know what the size of the bolts used, thread type, and the overall dimensions of the Nut Plates? To save myself the $50 (SLP's purchase Price for the kit) I would like to buy the 6 Bolts and Washers from the local Auto Parts Store and Have a friend machine up the Nut Plates.
Thanks in advance.
09-12-2005, 02:20 PM #2
Take it to an exhaust shop and let them weld the connectors in. Using bolt in subframe connectors, the bolt holes will stretch out after a couple of months of driving around corners and render your new investment useless.
09-12-2005, 07:24 PM #3
- THE SWAMP
Welded is better.
09-13-2005, 09:53 AM #4
- Yardley, PA
Black- 2001 Camaro SS
I don't like welding these in, but everyone has an opinion. You can get some 1/2 bolts to use, just make sure they are grade 5 or 8
09-15-2005, 07:25 AM #5rays00ramairGuest
i got the same conn.and i am going to have them welded. the bolts do move.want a more solid car.thats why we got them in the first place right.anyes mine are bolted in now
09-23-2005, 12:00 AM #6
They will work just fine bolted in. I made my own hardware. I used 1/4 inch thick plate, and welded nuts to it for the front, and in the rear you can use large washers.
sub frame connector
By zeetwentyeight in forum General HelpReplies: 83Last Post: 04-28-2010, 09:09 AM -
What is this connector for?
By Bassplayer92 in forum Stereo and ElectronicsReplies: 13Last Post: 05-12-2009, 12:31 PM -
What do you think of SLP's SFC sub frame connector
By BKDZ28 in forum General HelpReplies: 5Last Post: 10-08-2008, 07:57 AM -
What for is the second connector?
By swisscheese in forum Stereo and ElectronicsReplies: 3Last Post: 05-21-2008, 12:43 PM -
Sub Frame Connector Install
By 00 Z28 in forum Suspension and HandlingReplies: 8Last Post: 09-17-2006, 03:18 PM
