Thread: A4 wont shift
08-21-2006, 05:26 PM #1Member
- Aug 2006
- NC
mystic- 95 LS, yes it says LS
A4 wont shift
4L60E trans, every gear is drive. fluid is good but 1st though 4th is first to the trans. any help. I know this should be in the trans section, but more people look here(and I did post in the drivetrain sec). Any help is needed.
08-21-2006, 05:31 PM #2Junior Member
- Jul 2006
- Comstock WI.
White- 1999 Camaro LS1
i hit a piece of something on the road one time, and after that my car went thru the same thing, all that had happened was the linkage disconnected, you can still shut off and restart the car as long as you put the shifter in the Neutral postion.
does your park still work, or is that first gear also, cause if it is, then your linkage is disconnected. if you jack up the car from the side you should be able to take a look, if nothing is broke you can just press it back on, if the piece is broke, then youll have to replace it, hope this helps
08-22-2006, 04:06 AM #3
Yepp, I agree with z28, check out your linkage and see if its disconnected or broken.
08-28-2006, 11:05 AM #4Homebrew Master
- Aug 2006
- leesburg, florida
Arctic White- 1997 Trans Am
yessir...i just had my linkage fixed. it was the same way as yours...plus it was missing a bolt! ooh-muh-goodness!
08-28-2006, 12:44 PM #5Member
- Aug 2006
- NC
Ok, I replaced the cable. That half fixed the problem. Now when you put it in park it might still be in drive or reverse. Just depends on what it wants to do. Nutral is kind of tricky, sometimes you have to go to D1 then it will go in, the rest of the time I'm SOL. Any clues.
08-28-2006, 03:00 PM #6Member
- Aug 2006
- NC
Just by chance, is the cable adjustable if so where.
08-29-2006, 08:02 AM #7
Put the car in neutral, not the shifter but the tranny, then pull off the cable and put the shifter in neutral, then reinstial the cable. sounds like its just out of adjustment. Need too make sure the shifter and tranny are in sync.
J
08-29-2006, 08:09 AM #8Member
- Aug 2006
- NC
Thanks
08-30-2006, 08:59 PM #9Michael
In GA waving from '02 C5 LS1, Z51, D1SC, 60lb injectors,RPM level 5-4L60E, 3:42, Yank 3600, QA1-12 ways, MTI long headers, high flow cats, Borlas, Wilwood, 603rwhp, 542rwtq.(DynoJet 248-C) [email protected] on street tires, Race Weight 3,640 lbs
Help: my A4 wont down shift. Why
By mglangley21 in forum Automatic TransmissionReplies: 7Last Post: 03-27-2012, 08:37 AM -
wont shift!!!
By tangkiller_z28 in forum General HelpReplies: 0Last Post: 02-03-2011, 10:52 AM -
SHIFT HAPPENS...you wont believe this
By 02cetransam in forum Almost Anything GoesReplies: 13Last Post: 08-29-2007, 12:57 AM -
wont shift!!
By z28jerad in forum Computer & TuningReplies: 0Last Post: 08-21-2006, 05:35 PM -
wont shift from 2nd to 3rd @ wot
By todd in forum Automatic TransmissionReplies: 1Last Post: 01-02-2006, 05:36 PM
