Thread: sun visor
08-21-2006, 10:30 AM #1
sun visor
On the way to work today my passenger side sun visor just fell off. I dont even use it.........ever. Has this happened to anyone else and how can I fix it. It looks like the 90 degree fitting that inserts just wore off the lip that holds it in. Thanks in advance
2000TA, ARCTIC WHITE, 6 SPD
ALL THE USUAL STUFF
A MILE HIGH & A SECOND SLOWER
08-21-2006, 10:31 AM #2
Check the for sale section. People are parting out cars all the time so you shouldn't have too hard of a time finding a replacement.
08-21-2006, 10:33 AM #3
08-21-2006, 10:36 AM #4
08-21-2006, 11:00 AM #5
Glue and a stick of gum. Chew the gum while you glew it back on
08-21-2006, 11:04 AM #6
08-21-2006, 11:43 AM #7Member
- Westminster, Md
NBM- '99 Z28
It happened to me. I had to buy a new one.
08-22-2006, 05:12 AM #8
OK folks, it's fixed and fully functional. The spring tension just wears off the cheap pot metal flare, so I used a flat washer to mate up with the spring, on top of that I used a small diameter lock washer, then a self tapping sheet metal screw with a hex head. It worked just right, problem fixed. Now if I could fix those door panel cracks..........
Wanted: Sun Visor
By kingls1 in forum Parts Wanted / TradeReplies: 0Last Post: 05-19-2011, 06:00 AM -
Sun Visor Replacement?
By Robreynolds in forum Appearance SectionReplies: 4Last Post: 03-06-2010, 11:52 PM -
Question: Visor bracket
By KahanaReef in forum General HelpReplies: 12Last Post: 01-13-2010, 07:50 AM -
sun visor
By guitarjay76 in forum General HelpReplies: 1Last Post: 05-16-2009, 01:15 PM -
Sun Visor Screens
By Selride in forum Stereo and ElectronicsReplies: 1Last Post: 09-28-2007, 05:29 PM
