08-21-2006, 10:14 AM #1
Harris Speed Works- Brute Force installed.
Harris Speed Works- Brute Force Dual Nozzle Wet Kit is installed.
Matt at HSW was a pleasure to deal with. and helped with my bazillion calls and questions.
I got the 360 wrapped heater and purge. waiting on fedex to deliver the blow-down and filter.
Putting in the TR6 plugs tonight.
Instructions and kit is awesome.
Excellent customer service.
08-21-2006, 12:42 PM #2Grand Imperial Wizard
- Retired Outlaw Sum Bitch
Nice....where is your throttle switch? Did you put it under your foot pedal?
FP cutoff switch and throttle switch are peanuts and can/will save your engine....clean install man...looks very nice....keep that bottle pressure above 900!
08-21-2006, 02:05 PM #3IYPGuest
looks good man, what kinda shot you running?
{edit}
uhhh do dual nozzle wet shots work off 4 solinoids or 2?
08-22-2006, 08:40 AM #4
Throttle switch is located at the throttle body, so it'll only kick in at WOT
and for wet kit there are two NOIDS, and one for the purge
Here is the switches from left to right
Main ,. purge, bottle warmer.
08-22-2006, 09:06 AM #5Grand Imperial Wizard
OK....good man...looks good....here is my setup ( Pre 402 Stroker)..
08-22-2006, 09:36 AM #6
Looks good..
I'm going to mount my bottle in the spare tire space.
08-22-2006, 12:23 PM #7IYPGuest
hows that ashtray switch work for you?
Wanted: Harris Speed Works Microedge Plus
By tug686spd in forum Parts Wanted / TradeReplies: 1Last Post: 03-23-2017, 09:52 PM -
Convert dry to wet? Harris Speed Works.
By nabdrill in forum NitrousReplies: 2Last Post: 04-09-2007, 03:05 PM -
Dyno Day @ Harris Speed Works
By Matt@HSW in forum Eastern MembersReplies: 0Last Post: 04-06-2007, 01:16 PM -
Nice save Harris Speed Works!
By Rich L in forum NitrousReplies: 9Last Post: 03-23-2007, 12:32 PM -
harris speed works dry lsx kit w/accesories
By FreakV6 in forum Parts For Sale / TradeReplies: 4Last Post: 02-24-2007, 09:54 AM
