Thread: Fitment Question
08-15-2006, 09:17 PM #1Junior Member
- Rancho Santa Margarita, CA
Black- 2002 Trans Am
Fitment Question
There used to be a post a while back on here that was called, "Will this fit" which had a lot of good information about what wheel size and tire combinations would fit. Since that is gone, I need to ask some questions.
I am finally getting around to replacing my stock silver 16" rims. The rims I am looking at are the ASA JS5 chrome rims from Tire Rack. http://www.tirerack.com/wheels/Displ...wheelModel=JS5
The specs on the rims are 17" x 9" with a 50 mm offset.
I am going with 275/40 tires (probably the BFG g-Force T/A KDWS, or the Fuzion ZRi).
What I need to know is if this rim at a 50 mm offset will fit without having to do any modifications or the use of spacers? The car is a 2002 Trans Am and sits at stock height with no plans to lower it. It is a daily driver with Bilstein shocks from Strano and the stock springs.
Bonus question: Can I use my stock lugs, or do/should I buy new lugs and what type?
Thanks for your help.
Jim
08-16-2006, 07:47 PM #2Junior Member
- Aug 2006
- El Paso, Texas
Black & Red- 85 Iroc-Z and 00 Trans Am
They will fit and yes you will have to get new lugs for them. Head to a tire and wheel shop and they should be able to get you the correct lugs for it.
2000 Trans Am-LS1 what else do you need to know?
1985 Iroc-Z 305+TPI+Comp Cams+TCI+HOOKER=FUN!
08-17-2006, 02:13 PM #3
if those wheels accept acorn style lugnuts, then the stock ones will work.
08-17-2006, 07:18 PM #4Junior Member
Thanks
Thanks for the info.
Question: Miro 111 fitment question
By Boothe in forum Wheels and TiresReplies: 0Last Post: 04-21-2014, 10:45 AM -
SLP lid fitment question?????
By trtexasaf101 in forum External EngineReplies: 11Last Post: 12-30-2010, 11:16 AM -
Question: fitment question
By 02silverbird in forum Appearance SectionReplies: 0Last Post: 06-12-2010, 07:52 PM -
Question: wheel fitment question
By pontiacgp759 in forum Wheels and TiresReplies: 1Last Post: 05-22-2010, 09:08 PM -
01 Ws6 Fitment Question
By vipVEGAS in forum Wheels and TiresReplies: 1Last Post: 08-21-2006, 05:33 PM
