Thread: need help with cooling
08-14-2006, 08:08 AM #1Junior Member
- dover delaware
sport gold matalic- 98 firebird formula
ok so i just replaced my water pump and put in a 160 thermostat filled it up with coolent and now im still geting a low coolent light......
my radiator is full and so is my over flow box... any suggestions???
08-14-2006, 08:35 AM #2
What year is your ride? Lt1's are famous for this issue, try pulling out the sensor on the rad and cleaning it up. Did you make sure there isnt any air in the system?
08-14-2006, 08:37 PM #3Junior Member
- dover delaware
its a 98 ill try cleaning the sensor. when i drove to work today about 30 min the light came on and off twice but the temp stayed around 180, until about 5 min from work the temp went up to 210 deg. drove home and it stayed around 180, let it idle for about 15 min. and the temp only got to the first line after 160.....
thanks for the replies
08-14-2006, 10:24 PM #4
Sounds like you have air in the system. Purge the air and that should cure your problem.
Question: cooling
By 2000dreambird in forum General HelpReplies: 16Last Post: 07-20-2009, 07:01 PM -
Help: Cooling
By repeter in forum GTOReplies: 2Last Post: 11-12-2008, 10:49 AM -
Cooling down
By Mike's02Z28M6 in forum Computers / GamingReplies: 7Last Post: 03-07-2008, 07:04 AM -
help with a/c not cooling
By clown1000 in forum General HelpReplies: 10Last Post: 06-14-2007, 05:39 AM -
Cooling Iat's with N2O
By whitelite in forum Forced InductionReplies: 2Last Post: 03-05-2007, 07:32 AM
