Thread: Hesitation at 46MPH.
09-10-2005, 09:28 AM #1
- florida
white- 1999 trans am
I have posted serveral times on different forums and can't find an answer.
I have a 99' white trans am M6. When I'm driving and I go from 4->5 at 40, as soon as I get to 46MPH the car has a slight hesitation. It is almost as if it bogs down and then everything is normal again.
It isn't everytime I hit 46 MPH and i tried to slow down from 5th with no brake to see if it would cause anything at 46 but I felt nothing. I can feel it even when I'm in 4th gear (not as noticeable). When I'm at a full WOT I can't notice anything. What would be causing this? I am getting very annoyed at feeling it bog down at this speed. Also, If I slow down but don't stop, I won't get the hesitation. It is usually when I stop and then go. I don't really feel any problems with the clutch, and I don't get any slippage especially when I slam gears.
*Question: this doesn't pertain to my problem, but I was wondering, if you're sitting inside your car what side of the engine would a 'right' part be located. Would the right side of the engine be located if you're sitting in the car or facing it from the engine bay?*
09-22-2005, 10:40 PM #2
dude, i cant help you on your hesitation sorry, but the right side of the engine is the passenger side. like you are sitting in your car.
09-23-2005, 09:08 AM #3BeastGuest
Is it only when in those particular gears, or does it always happen at a particular RPM?
I ask because the first sign of my fuel pump going out was that it would slightly bog after 2500 rpm.
09-23-2005, 08:19 PM #4
- Sep 2005
- Fort Stockton, Tx
Blue- 2000 Z-28
is the ses light on? i had a similar problem that eventually got worse. the problem was one of the front O2 sensors was bad.
Hesitation
By staleycornell in forum General HelpReplies: 10Last Post: 02-09-2011, 03:46 AM -
LS1 Hesitation?
By GrapeApeTA in forum General HelpReplies: 7Last Post: 09-27-2010, 08:02 AM -
Need Help, hesitation
By ESBdieselcam in forum General HelpReplies: 14Last Post: 10-15-2009, 06:07 AM -
Hesitation
By WormzWs6 in forum General HelpReplies: 4Last Post: 11-05-2008, 07:50 AM -
Help with hesitation
By BruceLee in forum General HelpReplies: 5Last Post: 05-09-2007, 02:55 PM
